460 rear main
Old Apr 28, 2008 | 06:31 AM
rbtjawjaboy's Avatar
rbtjawjaboy
460 rear main
I'm gonna make the painstaking attempt to replace my rear main seal this weekend. i have an auto tranny. any advice or thoughts? is there anything other that the seal and oil pan seal that anyone would replace while i have it down????....
Old May 5, 2008 | 08:33 AM
kdy72601's Avatar
kdy72601
since you have to pull the motor go ahead and replace the front main, dip stick o-ring, and check the front pump seal on the tranny.
Old May 5, 2008 | 10:00 AM
haroldrussi's Avatar
haroldrussi
If yours is in a PU you might have to pull the engine like KDY72601 says. I would change all the gaskets and seals as well as checking the clearances on the bearings while you have it out anyhow. Good luck....
mikev
Nov 12, 2010 02:01 PM
DT 466Man
Apr 29, 2005 10:41 PM
a9464
Jul 24, 2003 08:08 AM
adroc104
Apr 3, 2003 08:27 PM
stevieray
Apr 25, 2002 05:07 PM
