no odometer no lights nothing help
Old Apr 28, 2008 | 05:48 AM
bambam634's Avatar
bambam634
Exclamation no odometer no lights nothing help
I just replaced an alternator on a 1996 ford explorer and I went to start it up and this is what i got (the alternator works too )
no dome lights
no door chimes
no speedometer
no odometer
no front windsheild wipers or wiper fluid
no rear wipers but i do have fluid
Air bag light is on
radio works
turn signal works
lights work
I checked all of the fuses and they worked I checked the wiper motor and it had pos and neg to the motor I am so confused if you can help please do so or and comments would help out a bunch
thanks Josh
Old Apr 28, 2008 | 12:20 PM
marragtop's Avatar
marragtop
Did all of this work before you replaced the alternator? Also, did you disconnect the battery when replacing the alt? There may be relays that control those items. Check your owners manual, or you can look here... </title></head>"); newWindow.document.writeln("<body><div align='center'><img " + getWidth("yes") + "src='/images/cds/" + tpe + "/" + sze + "/" + pc + "." + tpe + "'></img></div>"); newWindow.document.writeln("<div align='center'><table><tr><td><FORM
Old Apr 28, 2008 | 12:54 PM
bambam634's Avatar
bambam634
yes they all worked before and i hve checked all the relays thanks
