Mileage decreasing
Old Apr 28, 2008 | 02:07 AM
hogfmr88's Avatar
hogfmr88
Mileage decreasing
I was wondering why the mileage on my old 91 F-150 with a 300 I6 is going down. It used to get 17-18 regularly, but it now is getting just 13-14.
Old Apr 28, 2008 | 12:24 PM
5.0Torx's Avatar
5.0Torx
because parts wear out?????????????
Old Apr 29, 2008 | 03:58 PM
adipose's Avatar
adipose
try some new plugs, plug wires, cap and rotor. some fresh oil and that should help right off the bat.
Old Apr 30, 2008 | 09:06 AM
AbandonedBronco's Avatar
AbandonedBronco
How many miles are on the engine?
Do a compression check (can get a compression tester for like $20), clean your air filter or replace it, check to see if you have a plugged cat (most exhaust places will check it for free), run some sea foam through your engine, new plugs, plug wires, cap, rotor, tires inflated correctly, new fuel filter, etc....
It's amazing what just a freshening up of parts can do for you. Anything that restricts the engine's potential should be replaced, especially if you're getting a drop of 3 - 4 mpg. If those easy things don't do it, then it's time to check to make sure your engine isn't just wearing out.
