wrong engine oil...oops!
Old Apr 27, 2008 | 11:20 PM
goodB0Y's Avatar
goodB0Y
hey everybody...I did an oil change today and realized that I put castroll 10-40 instead of 15-40...the container says nothing about being good for Diesel's...anyone have any ideas as to if this oil is ok...
thanxs,
Corey
p.s. 1991 7.3 idi
Old Apr 27, 2008 | 11:43 PM
Dodge/Cummins's Avatar
Dodge/Cummins
Some oil is better than no oil.
BUT drain it and put in 15W40, I'm kind of cheap so I would probably pull the filter, drain it and put it back on.
I'd use the oil in what ever you origionally bought it for too. Just make sure and drain it into something REALLY clean. I can't imagine the little bit of 10W40 left in the filter is going to hurt anything.
I don't know for sure about your truck but some owner's manuals say you can sustitute oil in VERY low tempuratures but the HOT time of year is coming.
You aren't going to be LOSING anything so it's a no-brainer.
Old Apr 27, 2008 | 11:57 PM
1970 Boss 302's Avatar
1970 Boss 302
No you should not use gasser engine oil in a diesel engine. They are not the same oil. I believe gas engine does not have the same temp.rating as a diesel engine oil. Diesel engine oil must work harder and I believe has more additives than gas engine oil. If I am wrong I hope some one surely correct me .
Old Apr 27, 2008 | 11:59 PM
Dave Sponaugle's Avatar
Dave Sponaugle
What is the API rating?
The S part of the rating is for gasoline engines.
The C part is for diesels.
CD or CE and you are good to go.
Old Apr 28, 2008 | 10:27 PM
royzell's Avatar
royzell
'you could always put the 10-40 in your fuel tank.....
Old Apr 28, 2008 | 10:39 PM
1994diesel's Avatar
1994diesel
haha, there you go! its a win-win situation.
Old May 3, 2008 | 10:41 AM
goodB0Y's Avatar
goodB0Y
thanxs for the replys... and thanx dave for the info but I threw out the container... think I'll just dump the oil and call it an engine flush, an expensive engine flush the oil cost me like 40 bucks!!! Dam that buy's alott of beer!
Corey
Old May 3, 2008 | 06:17 PM
snubber's Avatar
snubber
Maybe this can help
http://www.castrol.com/castrol/LubesSelector.do
Or call their helpline. Some guys over here use 10w30 all year.
