Question on Traction?
Old Apr 27, 2008 | 10:41 PM
F700 Pickup_man's Avatar
F700 Pickup_man
first let me say I know the power is there, but.. it spins it is a base model no 4 wheel drive, so I know there will be limitations, but I think it might just be tire selection or the weight or lack thereof in the bed.
I got my tractor stuck digging out beaver dams, just the front end of it.
chained my ole truck to it made it jump a few times (tractor) but could not get it moved, ground was dry, but I spun so much it was unreal.
The question: if I get a tire with a more agressive tread will this help a little more?
I have no doubt about the power but just the bite into the surface is off for my tatse, I also have a 6 degree sloped drive and when pulling the tractor I do feel just a little slip, not much I checked to make sure it wasn't gears or trans prob, its not, tires have plenty of tread, I think they are just street tires.
thanks sorry i was long winded
Old Apr 27, 2008 | 10:56 PM
RubberDuck's Avatar
RubberDuck
More agressive tread will help some. Also a limited slip or locker will help. But as far as getting weight in the back.... There was a product out not too long ago that was a large square bag that you put in the bed and filled with water. It was very slick if I do say so. But I can't for the life of me remember what the name of it was.
Old Apr 27, 2008 | 10:59 PM
immastrokinnow's Avatar
immastrokinnow
i think jcwhitney has those weight bags. check them out
Old Apr 27, 2008 | 11:03 PM
Robbgt's Avatar
Robbgt
You Guys talking about this???
ShurTrax, Traction Control, CLICK HERE!
Old Apr 27, 2008 | 11:13 PM
RubberDuck's Avatar
RubberDuck
Exactly Robb, Damn, you are on fire tonight!!!!
Old Apr 27, 2008 | 11:19 PM
F700 Pickup_man
LOL while I appreciate the advice,
that thing looks like a pain in the ****
no offense intended
Old Apr 27, 2008 | 11:22 PM
RubberDuck's Avatar
RubberDuck
Well, that's what flew off the top of my head. No offense taken. Other than, weight, or agressive tires, it's time for 4x4.
Old Apr 27, 2008 | 11:25 PM
F700 Pickup_man
ha ha
I figured I would just say what flew off the top of my head too, sorry that does kind of sound abrasive, I was just thinking of something quick, ya know
I suppose I could have said that in the original post, but by being a pain I meant the strapping it down, filling it, and then doin whatever.
I can sound crass at times
believe me the 4x4 part is being heavily considered, just gotta run it by the boss (wife) and justify it the right way
Robbgt's Avatar
Robbgt
Cody: Just rippin up the form a bit before bed (getting up in 6 hrs...)
F700: Yea it would probably be a pain, but with 4x2, going to need to consider a few things: Open diff means 1 wheel gets traction... not the best thing if you need some traction. Aggressive tires will help, however you need weight on them to be affective... catch my drift?
-Robb
Old Apr 27, 2008 | 11:32 PM
F700 Pickup_man
I got ya, after it was mentioned, I actually considered my rain barrels in back of the truck, 50 gallons each got four available, put em in fill them, wow a lotta work either way, I think this put the right way could justify the expenditure, if not resort to what I did when I needed a new tractor............(BEG)
Old Apr 28, 2008 | 01:40 AM
884x4broncoII's Avatar
884x4broncoII
around here in the winter time menards carrys sand bags that are the the with of a truck bed and something like 75 lbs a piece they dont normaly have them on display in the summer but you could go in and ask them if they can get some for you
Old Apr 28, 2008 | 09:02 AM
93f1505.0L's Avatar
93f1505.0L
I had a 2wd at one time and now I have a 4x4. No matter what you do nothing will compare to the 4x4 for sure. The only other thing I can think of woud be getting a bigger strap to get a longer run at it lol but I wouldnt recomened that. The truck my not like it.
Old Apr 28, 2008 | 10:31 AM
secondarychaos's Avatar
secondarychaos
Ya, for a quick physics lesson,think of it this way-
traction is basically just friction
(friction)=(Weight)*(Frictional coefficient)
Adding weight will be the biggest help short of 4x4.
Meaty tires will increase your F C, but maybe five percent.
Open diff means as soon as one tire loses traction, you're pullin with half the force, because theres only half the weight. look into a locker.
4x4 would help with the weight problem (1000 lb engine over front tires) and with the differential problem( 3 tires spinning b/c fronts usually wont slip on dry ground)
Good luck!
The only other option i can think of would be a ******-block setup if you have anchor points.
Old Apr 28, 2008 | 10:40 AM
Robbgt's Avatar
Robbgt
Haha I like it! Basically the same exact thing as from physics book:
F<sub>r</sub> = μN
F<sub>r</sub>
is the resistive force of friction
μ
is the coefficient of friction for the two surfaces (Greek letter "mu")
N
is the normal or perpendicular force pushing the two objects together
μN
is μ times N
Ok enough physics for one day... Time for some chemistry!
-Robb
Old Apr 28, 2008 | 10:42 AM
secondarychaos
Ya, i didnt want to take the time for the Static Vs Sliding...
Just figured i'd make it simple.
Robb, are you a Student of Physics?
