help wont start
Old Apr 27, 2008 | 02:41 PM
sp metalman's Avatar
sp metalman
Question help wont start
I have a 94 F150 4wd 302 5speed that wont start you can turn the key and it wont do anything but you can cross over the fender mounted silonoid with a screwdriver and she will fire right up I replaced the siloniod and still the same thing whats a real kicker is after you cross over start it it will start with the key a while then nothing again and have to start it with a srewdriver again this is realy getting frustrating can anyone please give me an idea what is wrong so I can get it fixed.
Old Apr 27, 2008 | 04:27 PM
BCHauler's Avatar
BCHauler
I just went through this with my truck.
Check the fender mounted solenoid (also called the starter remote relay). Check the small push-on connector at the top in the middle. That is the signal feed from the ignition switch. On mine the connector was loose and corroded, thus giving an intermittent start situation. If the relay clicks when you turn the key, however, this isn't the problem.
Old Apr 27, 2008 | 04:35 PM
OldRed4X4's Avatar
OldRed4X4
Mine did the same thing but mine was not help secerly to the fender so it was not contacting right two new sheet metal skrews and no more problem
Old Apr 27, 2008 | 04:38 PM
ri_truck_guy's Avatar
ri_truck_guy
Those two sheetmetal screws are the ground for the solenoid. Make sure they are clean.
Old Apr 27, 2008 | 07:18 PM
sp metalman
Thanks for the info and by the way it does click when you turn the key when it dosnt start.
Old Apr 27, 2008 | 07:22 PM
ri_truck_guy
Most parts stores, at least the chain ones, can test your starting and charging systems. Could be the load from the starter is too high.
Old Apr 27, 2008 | 07:24 PM
netscaner's Avatar
netscaner
If it clicks and doesn't crank, then probably it is a bad connection on the spade connector on the little wire that attaches with a spade connector down by the starter.
It is a common problem with these trucks.
Old Apr 27, 2008 | 11:16 PM
Creel's Avatar
Creel
Very likely!! I thought my starter was toast untill I bought a new one and started to change it and noticed the spade connecter was very loose on the old one, took a pair of plyers and carefully tightened up the connecter befor I put it back on, problem solved. Glad the guys at parts store let me return new one without the restock fee.
