203 Thermo
Old Apr 27, 2008 | 01:19 PM
cps's Avatar
cps
203 Thermo
All you guys that have switched your stock thermo to a 203 deg, did it make much of a noticeable difference in engine performance? Did your dash gauge read any higher? Roy.
Old Apr 27, 2008 | 01:22 PM
That_Guy's Avatar
That_Guy
subscribing...id like to know also
Old Apr 27, 2008 | 01:30 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I couldn't feel any difference once I installed the 203* stat. The gauge on the dash is a glorified idiot light, It wont move like a regular gauge. Didn't feel any more performance either. Sorry, I did it because they say my engine likes it hot.
Old Apr 27, 2008 | 02:02 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Its only really a mod to do if you pull yours out, or if it leaks. I didn't notice a damn thing when i put mine in.
Old Apr 27, 2008 | 02:14 PM
jrciii56's Avatar
jrciii56
Same here, nothing.
Old Apr 27, 2008 | 02:28 PM
brwolfjr's Avatar
brwolfjr
I put the 203 in when I developed a leak. I didn't notice any gain in power or mileage.
Old Apr 27, 2008 | 10:58 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Damn! Me Neither!
Just thought of this, when my water pump was leaking, I took it to David at DI Performance and he said even though my pump was leaking, it would probably never overheat; simply because the cooling system on our trucks is so efficient that it just wouldn't, even with a leak! (he was right btw) In the years that he's been working on diesels (mainly Powerstrokes) he's never seen one overheat unless it had the short stem 203 thermostat.
In plain english, I think that with the efficiency of the 7.3s cooling system, it wouldn't do much. I'll head over there next week, have them hook up the NGS, and we'll see.
Old Apr 28, 2008 | 04:47 AM
sleek122's Avatar
sleek122
So what is the benefit of running the 203* T stat?
Old Apr 28, 2008 | 04:58 AM
ron's power stroke's Avatar
ron's power stroke
I know on the big trucks we swap out the 195 for a 210 stat..recommended by cat..don't know any diff's till you work the truck..when the temps are up and your pulling a hill.. we could feel it pull better..she also throws a lot better heat out the heater...DD guy's wont feel any power gains..just better heat.like said above..the 7.3 has a very good cooling system.if your pulling loads all the time..you should feel a little better power when she is pulling hills...
Old Apr 28, 2008 | 09:23 AM
UP_There's Avatar
UP_There
if it ain't broke.......don't fix it! Mainly the reason I haven't swapped mine out yet. If it ever fails.....or when I get tired of putting additive in my green stuff and make the changeover, I'll have the stocker 195 in.
Old Apr 28, 2008 | 01:00 PM
CSIPSD's Avatar
CSIPSD
Put a 203 in mine, and if your in a stockish truck go for it, a little quieter, little less smoke... but I am going to pull mine and put it in the wifes X and run a stocker... With the injectors and such my oil temp is starting to get in the 220-225-230 range... Water temp stays right at 200 but...
Old Apr 28, 2008 | 07:21 PM
cvdenson's Avatar
cvdenson
I just put mine in this past weekend. I seem to have slightly higher EGTs (maybe 25-50) over what I had been running, and the truck seems to have quieted down some. That's it.
Chris
Old Apr 28, 2008 | 08:08 PM
powerstroke1869's Avatar
powerstroke1869
the only thing i noticed was my heater got a lot warmer
Nicmike
Ford Truck Parts for Sale
Dec 9, 2012 12:42 PM
blk92prostreet
Nov 5, 2012 01:07 PM
cps
May 6, 2012 10:14 AM
Greywolf
Tennessee Chapter
Oct 26, 2006 05:01 PM
donjamer
General Automotive Discussion
Mar 28, 2006 05:44 PM
