Sponsored by: Auxito
No heat...
Old Apr 27, 2008 | 10:48 AM
rett8799's Avatar
rett8799
No heat...
99 F150 V6 2wd....When heat selected it blows cold air, not that i will need heat for some time, but was wondering where to start looking?
Old Apr 27, 2008 | 10:57 AM
05 super's Avatar
05 super
our 99 at work does the same thing. when you turn the dial from hot to cold and back to hot it stays cold. i've found hitting the black plastic piece on the floor, in front of where a manual tranny stick would be, helps. maybe vacuum related. also helped when **** was turned to ac and then to hot once in a while too, good luck.
Old Apr 27, 2008 | 08:11 PM
steve(ill)'s Avatar
steve(ill)
the temp controller is electric motor that runs a mixing door. hot air and cool outsidie are mixed to get the temp you want. first thing is to pull the **** off and see if the controller rod is moving. if it is, then the electric motor or the cam on the mixing door is bad.
Old Apr 27, 2008 | 08:15 PM
steve(ill)'s Avatar
steve(ill)
read this entire thread
https://www.ford-trucks.com/forums/6...irections.html
