Sponsored by: Real Truck
electrical problems
Old Apr 27, 2008 | 08:31 AM
champpydog's Avatar
champpydog
electrical problems
iI'm having a weird problem with my ac in my F250. When I accelerate the ac stops blowing out of the vents and blows up the windsheild as if the defroster is on , then when i slow down it goes back the vents. What the hell is that? Is it a relay or something mor involved? any help would be great.
Old Apr 27, 2008 | 12:44 PM
megawatt00's Avatar
megawatt00
I'm not 100% sure on this one, but there is a possibility that the blower motor isn't running. Maybe when you slow down it's takeing the path of least of least of least resistance. This will bump you back to the top and some one else will chime in.
Oh and by the way WELCOME TO FTE!!!!!!
Old Apr 27, 2008 | 01:00 PM
zx250's Avatar
zx250
Of the next Riffraff East
A vacuum is what controls the HVAC controls. I'm not sure what accelerating would have to do with it, but it sounds as if you have a leak in the vacuum lines. If you have a 4x4, the hubs and lines going to the hubs are a good place to check. A simple check of this system would be to unplug the vacuum lines at the soleniod and plug. Go for a drive and see if that fixes the problem.
Old Apr 27, 2008 | 01:38 PM
megawatt00's Avatar
megawatt00
See I told you that some one else would chime in with a better idea! Thanks Barry!!
Old Apr 27, 2008 | 01:54 PM
zx250's Avatar
zx250
Jim, let's just wait and see if I close.
Old Apr 27, 2008 | 09:32 PM
Topbob's Avatar
Topbob
You must have a gas engine because a diesel has a vacuum pump that is running whenever the key is on. With a gas engine, vacuum drops with acceleration and
increases with deceleration and at idle. You may have a bad vacuum reservoir-- a
small canister used to prevent just your problem. Hope I'm not lying about all this.
