I know why they say use antiseaze but wouldn't that make it so the plug can back out?
Wouldn't you want it to bind to the threads so it couldn't back out?
the reasoning behind never seize is this, you are dealing with an aluminum head. if the plug should seize to the head(far too common)when you turn plug you destroy the threads in the head. aluminum really loves to stick to steel, never seize provides a non corroding barrier between them. its also real good for the face where your wheels mount to the hub, alot easier to change a flat at 2:00 a.m. in the rain if wheel isn't rusted on
Thanks for the tip 99f350sd. In my searches I saw this covered alot too but I'll ask for the hell of it; Is the Bosh Bashing warrented or are some just pissed off that they paid a premium for their plugs and didn't get a huge mpg increase they shouldn't have expected anyway? The previus owner of my truck gave me Bosh Platinums (the type with 4 side electrodes) he had intended to install. I'm just wondering is it a bad idea to install these or just a bad idea to spend the extra loot or are they really a good plug?
I also just blew a plug 99f-250SD 5.4 triton. I talked to a ford mechanic today, he said there is an insert they can install. Not a helicoil. It has been a good fix rather than replacing the head. I asked if it was something I can do. He said if I bought the kit and the tools to install it. About a 1000.00 bucks. The dealer will do it for 300.00.
The timesert kit is only $300 or so.
Who the hell would pay $1000 for the kit. And you get more than a few repairs out of one kit.
I helped my buddy put the insert in his 99 4.6.
I took us the morning on his driveway.
The kit approved by Ford is not Timesert. Timeserts inserts are steel where as the Lock N Stitch the inserts are made of Aluminum. That is/was the reasoning. However having said that, I believe that Timesert is is also selling aluminum inserts now. I'm sure I read something on their website or at least on some suppliers website.
Did mine in the driveway in about half a day, someone mentioned two hours, not on these engines!!!
I changed mine at 80,000 miles after reading all the issues with this, better safe than sorry I figure.
use copper anit seize and be sure not to get any on the electrode, replace the coil-pack boots and springs while you are in there. the correct torque on the plug is the main thing on these engines to keep this from happening. The aluminum heads only have 3 threads for the plug to grab, they start to back out, you will hear what sounds like a valve tap, this is your warning. If you continue to drive the compression will bounce the plug once it is loose and then "pop". major problem.
FTE was a BIG help to me on this one...... Thanks!
P.S. I bought a Cornwell spark plug socket with a locking extension for this, you really need it to get the old plug out from beep in the head.
[quote=steelers06steelers;6143239]Did mine in the driveway in about half a day, someone mentioned two hours, not on these engines!!!
What insert did you use?
Sorry if I confused anyone, I replaced my plugs before failure.....
Dubya Bee
I think the Timesert repair is the way to go. Even if then inserts are steel.
Many on this board have also done this type of repair and I have yet to read of a failure.
The V10 board has some good reading on this.
i just had one blow out on my '99 5.4 after 306,000 miles. The tap i have won't fit into the head. is there any special tool that shops use to reach down in there?
I can do a plug change in a super duty in about 2 hours, but then again I've done so many I can do them blindfolded. My brother law and I had my blown and the 7 other plugs done in two hours, swear on my dad's grave. But with two sets of hands working, one fixing the blown plug and the other one doing the other plugs we probably shaved some time. He works for a Ford dealer and does them day in, day out. I liked the Ford kit we used, it locks the insert in place with little pins. He has never seen one problem back with the Ford kit fix.
