Compression test results.
Old Apr 28, 2008 | 01:18 AM
  #31
Hiflyer746's Avatar
Hiflyer746
I gotta agree that you need to retune the chip to get rid of the big oil tunes. I know for a fact that 1800 PSI sucks and when you get it up another 1000 it makes the world of difference.
Tim
Old Apr 28, 2008 | 07:54 AM
  #32
Izzy351's Avatar
Izzy351
Why is everyone thinking that his numbers are low on 80E?? I ran 294/601 on 80E -- his seem to be inline, unless those are the HIGHEST he got out of all his tunes...
Old Apr 28, 2008 | 09:02 AM
  #33
Kwikkordead's Avatar
Kwikkordead
It's the 1800 psi on the HPOP pressure that is wrong.
Old Apr 28, 2008 | 10:56 AM
  #34
Izzy351's Avatar
Izzy351
Agreed. There's something up there. Not to mention the metal shavings on the turbo!!! I kind of skimmed through the thread so I missed some of the details. Sorry -- got in a hurry...
Anxious to see how you get this all fixed up, Kris!!
Old Apr 28, 2008 | 11:44 AM
  #35
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Just talked to Kevin from BWD, and we're resolving the turbo issue
Old Apr 28, 2008 | 04:54 PM
  #36
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
That's good. I think the turbo is a bigger part of the problem than you might think. 1800psi, while low, is not at all uncommon when running a chip. That pump will probably do 2500+ with the chip removed.
Old Apr 28, 2008 | 07:30 PM
  #37
Tenn01PSD350's Avatar
Tenn01PSD350
Cylinder 1- 390psi
Cylinder 2- 380psi
Cylinder 3- 380psi
Cylinder 4- 380psi
Cylinder 5- 365psi
Cylinder 6- 400psi
Cylinder 7- 400psi
Cylinder 8- 385psi
What do you think?
Kris, I had something like this on my driver side:
2- 400
4- 375
6- 380
8- 400
Don't know if that helps at all. Your ICP ought to at least start out higher. I know the chip will use it up quickly. Let me see if I can find the graph of mine with chip and without. That might answer Jamie's question too.
Old Apr 28, 2008 | 08:07 PM
  #38
Tenn01PSD350
I posted about ICP here in this thread.
For those not interested enough to look, here is my log of ICP on the 120 race back with stock injectors and turbo. Curious what it looks like now with the hybrids.
Old Apr 29, 2008 | 09:04 AM
  #39
Kwikkordead
That is still a little low, but well above 2000. Is the spike from when the tranny shifted?
Old Apr 29, 2008 | 09:43 AM
  #40
Izzy351's Avatar
Izzy351
I have a feeling that's about what mine will be. It just feels weak on the high-end of the RPM range. Hoping those SS sticks will help...
I'd like to see where you're at now too, Mike.
Old Apr 29, 2008 | 10:02 AM
  #41
ernesteugene's Avatar
ernesteugene
Thanks for all the info Dan and Eugene. I don't know if this is a possiblity, but could the two fittings in the oil rail under the valve cover be leaking oil?
I have a continuous real time display of the ICP sensor on my CAT C7, and I was discussing my readings with a tech at Dr Performance. He said that a single bad injector can leak enough to reduce the rail pressure significantly, so a leak on the high pressure line could do that as well!
Originally Posted by jrciii56
How can we determine if there is a ICP problem?
Here's a way to do a crude road test, and I'll give my CAT ICP readings as an example of "normal" operation. On the flat at constant cruising speed I see about 2600 psi. As I increase load to pull a hill I see a slight decrease, which shouldn't exceed about 200 psi if all is well with the HPOP and injectors. Then as I crest the hill and coast in gear at idle down the other side at the same RPM, the ICP momentarily increases to about 3300 psi. This is because the injectors flow very little oil at idle, and it takes awhile for the excess pressure to bleed off and the ICP to return to normal. If you don't see this momentarily increase, it means you've got excessive flow at idle due to a leak!
Old Apr 29, 2008 | 10:20 AM
  #42
Tenn01PSD350
No, IIRC the log was started after I had locked up in OD and had a straight shot to roll into it. The spike was when someone ahead pulled into the left lane and I had to let off long enough for him to get over, then back into it.
Gene's observations seem to match my data as far as throttle position and ICP is concerned.
Old Apr 29, 2008 | 08:52 PM
  #43
PowerstrokeJunkie
Yes, i believe the IPR also remains near closed (or at least i think) during startup, that's why the ICP skyrockets to 2500ish when started up cold, it just takes a second to bleed the whole system down to the normal 600-700 when cold. I talked to Joey about it today, and he says it's just another case of a set of very oil-hungry stock AD's. Plus i don't think the 3800psi they were seeing a few months ago helped the poppets and springs any. Maybe that just loosened them up a little too much, because it was FINE with a stock pump before that. I can still produce up to 3500psi with this at the right time and pedal position just rolling into te throttle before it falls off.
Old Apr 30, 2008 | 04:50 AM
  #44
Kwikkordead
Yes, i believe the IPR also remains near closed (or at least i think) during startup, that's why the ICP skyrockets to 2500ish when started up cold, it just takes a second to bleed the whole system down to the normal 600-700 when cold. I talked to Joey about it today, and he says it's just another case of a set of very oil-hungry stock AD's. Plus i don't think the 3800psi they were seeing a few months ago helped the poppets and springs any. Maybe that just loosened them up a little too much, because it was FINE with a stock pump before that. I can still produce up to 3500psi with this at the right time and pedal position just rolling into the throttle before it falls off.
I think you might be right about those injectors, Kris.
I've noticed a very much more responsive engine start, now that I have a new set of Alliants installed. The truck can sit for a week and it starts right up, right now, with less than 2 seconds of crank time.
Before it would be a little bit longer, especially when hot. It would sort of taper up instead of the usual "bark" when it starts.
therigwelder
Dec 30, 2016 08:56 AM
jordanfs
Nov 17, 2016 07:09 PM
TruckerATK
Oct 4, 2016 04:31 PM
marshallstanford
Jul 15, 2016 06:42 AM
JGuillen99
Apr 27, 2016 04:26 PM
