front wheel bearings
Old Apr 26, 2008 | 01:23 PM
luvemhot's Avatar
luvemhot
I have a bad driver side wheel bearing out. Will I need any special tool replace the bad one and re-grease the others?
thanks for your help
Old Apr 26, 2008 | 01:32 PM
Sawbones25's Avatar
Sawbones25
2 or 4 wheel drive?
Old Apr 26, 2008 | 01:57 PM
luvemhot's Avatar
luvemhot
guess its not in my sig. I better fix that.
its a 4x4
Old Apr 26, 2008 | 08:14 PM
gator120's Avatar
gator120
Nothing special here. Also check your u-joint and seals while your right there anyway.
Old Apr 27, 2008 | 02:53 AM
twags6's Avatar
twags6
Here's Racerguy's writeup on how to replace the ball joints, which includes the removal of the whell bearing assembly and lists the parts you need to do it. This would be a great time to do the ball joints too if they're starting to get worn. https://www.ford-trucks.com/forums/3...ll-joints.html
Old Apr 27, 2008 | 10:08 AM
lhud's Avatar
lhud
When you replace the driver's side, go ahead and break down the passenger side like you were changing the rotor for access to the ABS sensor. Remove the sensor via the allen-head screw; then put in several shots of hi-temp water resistant wheel bearing grease by using a rubber adapter on the end of the grease gun. Pump in a shot or two, then rotate bearings several times to distribute the new grease. Repeat this process until the rotation stiffens up similar to the new bearing. I have done this on mine since replacing the driver's side and it has been over 200k miles since then with no bearing issues.
It's not a 100% prevention, but it is better than doing nothing.
busdriver47
Aug 10, 2015 08:44 AM
RDockery
Jul 26, 2015 08:07 AM
Fordtrucks123456789
Jun 22, 2015 08:18 PM
hughd
Apr 12, 2015 07:38 AM
garydmundy
Jul 3, 2013 12:22 AM
