e40d swapping blues
Old Apr 26, 2008 | 08:16 AM
thomas k's Avatar
thomas k
e40d swapping blues
i have 90 f150 my speedo is gear driven my new used tranny is e40d from a 92 e250 which is magnetic is there a way to make mine work if not will it effect tranny from shifting
Old Apr 27, 2008 | 10:08 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I don't know what the aftermarket has. There might be a kit, but I wouldn't even know where to look.
You could take the output shaft out of the old trans and install it in the new one. The hard part is that both transmissions have to be completely disassembled to do it.
I tried to reply to yur PM, but I got a message that your inbox is full.
Old Apr 27, 2008 | 08:08 PM
subs1000w's Avatar
subs1000w
your trans will not shift right with out the vss signal the other way to do it is to swap in a newer rear end that has the vss
