Spring Hangers
Old Apr 26, 2008 | 12:02 AM
jmadsen's Avatar
jmadsen
Spring Hangers
I have a rear section of truck frame 51-52. I purchased it as a trailer for the bed and fenders.
I want to remove the springs, I have been reading about all the fun ways of removing them and decided I definitly dont want to do it Bobby's way, should I just torch or grind off the rivets attaching the hangers to the frame? (seems like the quickest & easiest way since I wont be using the frame)
I want to salvage anything I can off the frame and even then I'm not sure I would recylce it right away, just in case I can use part of it for something.
thanks
Josh
Old Apr 26, 2008 | 08:00 AM
cmoritz's Avatar
cmoritz
I personaly would love to be in Bobby's driveway with a few frosties and a lawn chair..., as he goes about taking on the frame-rivit removal ' procedure'....LoL!
I'm pretty handy with a torch though, with a torch and a pointed tip in the air-chisel, I could have them all layin on the ground smokin, in about 15 min.
Old Apr 26, 2008 | 08:09 AM
havi's Avatar
havi
I'll have the Roast Duck
Or substitute the torch for an electric grinder You can be a bit sloppy if you don't plan on saving the hangers or frame. But taking them off with the springs would make it easier to remove the springs with a shop press. Wish I was in Bobby's driveway too. It's snowing/freezing rain right now.
Old Apr 26, 2008 | 09:07 AM
Randy Jack's Avatar
Randy Jack
I prefer using a chisel in an air hammer. I use a cutoff wheel in a grinder to cut an "X" in the head (to allow it to fold up), then chisel the head off with the air hammer and punch the rivet stem out. Works real slick.
Old Apr 26, 2008 | 09:34 AM
jmadsen's Avatar
jmadsen
thanks, I think ill try the drill/chisel since I'm not all that great with the torch yet! guess i'll see how thta goes anyway
Josh
66with352
Feb 2, 2014 09:23 AM
From the Fifties
Feb 11, 2012 08:17 AM
slidingdelta
1983 - 2012 Ranger & B-Series
Feb 17, 2011 04:11 PM
Stumpalump
Colorado Chapter
Jun 12, 2008 01:05 AM
bbslamjam
Mar 3, 2006 11:17 PM
