Trouble!!
Old Apr 25, 2008 | 09:12 AM
schlepprock250's Avatar
schlepprock250
Trouble!!
Hey guys, Im doin my ATS housing/ WW and Bellowed uppipes, Ok the trouble is there is a rod (??) that is going into the base of the pedistal and it has a little plastic sensor.....Ok when I was taking out the turbo it hit the plastic sensor and broke it. Now....what is this called and will the dealer have one ( I say dealer because I know napa will not have it ).
Thx in advance...Schlepprock
Old Apr 25, 2008 | 09:19 AM
jwhitetail's Avatar
jwhitetail
Sounds like the Exhaust warm up butterfly control, thats what operates that rod you were asking about. That sensor you broke should be on the pedestal right under compressor.
Old Apr 25, 2008 | 09:25 AM
Kwikkordead's Avatar
Kwikkordead
I agree, it sounds like the EBPV solinoid.
You'll do just fine without it unless you want it to remain for use as an exhaust brake or something like that.
Old Apr 25, 2008 | 09:28 AM
schlepprock250
so if I dont replace it its no big deal....thats what youre saying?
Old Apr 25, 2008 | 09:31 AM
schlepprock250
If I want to use the EBPV this winter I just have to buy the solinoid??
Old Apr 25, 2008 | 09:32 AM
1996pwrstrk's Avatar
1996pwrstrk
If you have a camera post a picture just to be sure but that's what it sounds like.
Old Apr 25, 2008 | 09:34 AM
ron's power stroke's Avatar
ron's power stroke
is this what you mean???(just above the blue dot) if so..i have a spare from me early 99 set up..i think there same..
Old Apr 25, 2008 | 09:39 AM
schlepprock250
Yep....thats the one....Thx
Old Apr 25, 2008 | 09:43 AM
jwhitetail's Avatar
jwhitetail
Ron great pics, it will help him out, if he is using the stock butterfly i would fix it, if not i would do the pedestal change and butterfly delete. Since he has it off, and check for play in the shaft, bearing that is.
Old Apr 25, 2008 | 09:58 AM
ron's power stroke
thats great...it wont hurt to run it unhooked..your EBPV just wont close..if you need mine..just let me know...
Old Apr 25, 2008 | 10:46 AM
schlepprock250
Thx for the pics, and thx to all that replied. Im gonna see if theres one close by to go ahead and replace it if not ill let ya know on the one you have. I wasnt sure what all to do to delete the ebpv. I know I had to order a non-ebpv pedistal but I wasnt sure what else had to be done. Ive read on here that you had to plug this and cut off that and it all seemed kinda confusing. So far the ATS housing/WW uppipe job has not been as bad as I thougt it was gonna be. The hardest thing so far is having to climb my big @$$ on top of the truck and undr it( 6'3 260lbs)
schlepprock250
24
Dec 7, 2011 05:35 PM
Mrs.Schlepprock250
17
Jul 23, 2010 12:34 PM
schlepprock250
15
Dec 28, 2008 07:34 AM
schlepprock250
13
Dec 2, 2008 01:37 PM
schlepprock250
Apr 28, 2008 02:53 PM
