poorly plumed vacuum
Old Apr 24, 2008 | 10:09 PM
caplette's Avatar
caplette
I got a 73 F100 pickup i picked up about 2 weeks ago. And I've been trying to figure out the vacuum lines cause it looks like some one had gottin carried away and got it wrong. it don't idle worth the dam but mite have it figured out but now im missing conections on my carb. I'm lost now i need help
Old Apr 24, 2008 | 10:26 PM
fastfarmer's Avatar
fastfarmer
You'll need to post more details-engine, trans, etc.
Old Apr 24, 2008 | 10:52 PM
caplette's Avatar
caplette
its got a 390 auto trans, 2 barrel carb. i kind of re-routed a vac hose to the distributer cuz the one that was on there wasn't doing wut it was suppose to. who ever did it the last time, they just ran a hose from the side of the carb to the vacuum advance, kinda defeated the purpose.
Old Apr 25, 2008 | 02:19 AM
Dirt racer's Avatar
Dirt racer
It should run from the carb to the distriburter. If you run the vacuum from the intake your adavance will be backwards were it should be. You will have full vacuum to the advance at idle and no advance at wot.
Old Apr 25, 2008 | 03:31 AM
montana_highboy's Avatar
montana_highboy
There is no vacuum present at WOT, you can either connect the vacuum advance to a timed/ported source (above the throttle plates) or to a manifold/full source (below the throttle plates) the general rule of thumb is emissions equipped engines use ported vacuum and non-emissions equipped engines use manifold vacuum.
Old Apr 25, 2008 | 04:12 PM
n9lhm's Avatar
n9lhm
Where's Dennis (Mil1ion)? I can't believe he hasn't jumped in here with a diagram.
Old Apr 25, 2008 | 05:51 PM
caplette's Avatar
caplette
thank guys i tried to re-route it last nite and the dam thing quit on me this mornin. had a buddy help me to get it runnin,theres 2 ports under the carb one of them is runnin to some kind of thermistatic vavle by the distributor and that was routed to the intake manifold, and the advance off the distributor was plumed into the other port on the side of the carb! which now sputters but runs. HELP??
Old Apr 25, 2008 | 06:04 PM
caplette's Avatar
caplette
thanx guys i tried to route it last nite and thought i had it when it quit on me this mornin, had a frend help me get it runnin, had to re-route some hoses it runs now but sputters at low speed! HELP?
Old Apr 25, 2008 | 06:39 PM
tuckerjw's Avatar
tuckerjw
You need mil1ion's diagrams. If you can find his gallery they all all there. He should chime in here any minute.
Old Apr 26, 2008 | 03:55 PM
73f100shortbed's Avatar
73f100shortbed
Here is Mil1ion's vacuum diagram for 360(390 is the same basically). All this stuff is in his gallery.
lyndonff
Dec 1, 2020 03:07 PM
Frdtrckfn
Mar 2, 2014 07:45 PM
acfd813
Nov 24, 2013 03:26 PM
DanielT28
Jan 31, 2013 07:58 AM
