clutch ???
Old Apr 24, 2008 | 08:51 PM
ALW's Avatar
ALW
clutch ???
Does anyone know how the self adjusting system works. Is it in the clutch,on the release fork or in the hyd system .I;m going to see if I can find a diagram ....Thanks Al
Old Apr 24, 2008 | 09:07 PM
speedrdr's Avatar
speedrdr
not for certain sure, but i'm thinking it's hydraulic slave cylinder. the thing that's between the fork and the throwout bearing. i'll try to find my service manual and get a better answer for you.
speedrdr
Old Apr 24, 2008 | 10:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The slave cylinder only retracts till the pressure is off the pressure plate.
No adjustments.
Old Apr 24, 2008 | 10:07 PM
ALW's Avatar
ALW
I thought I could solve my problems with a longer rod on the slave, but no. So far I've change the slave then the master .I'm sure Ive got the air out. bushings are good,firewall ck no slop in the release fork ????????????????/ Al
Old Apr 24, 2008 | 10:15 PM
Dave Sponaugle
What truck, what problem?
You may need to adjust the master cylinder rod, or if the rod is not adjustable you may need to remove the clutch arm the master cylinder rod attaches to.
Old Apr 24, 2008 | 10:47 PM
ALW's Avatar
ALW
94 f-250 no adjustable rod there ,I wish their was .can;t find one . thinking of making one. those heim jonits are a rare bird around here. If I could thread part of the master rod . find the right theim joint I'd be good to go. Al
cinbearcat
Escape & Escape Hybrid
Nov 30, 2013 05:52 PM
fordfinatic
Feb 7, 2009 09:04 AM
lamouchr
Jun 10, 2008 10:09 PM
f100guy
Feb 18, 2008 07:44 PM
baz
13
May 23, 2003 01:18 AM
