how much?
Old Apr 24, 2008 | 06:57 PM
bigdieselrig's Avatar
bigdieselrig
how much?
hi guys i was looking at this really nice black f-250 superduty, with a black leather interior and the fX4 package a very nice truck! It has about 90,075km on it i am guessing it probably has the 6.0L powerstroke diesel in it but 100% sure though? Anyways with all the options on it and the mileage on it my question is how much would the price be for a truck like this : Canada Used Autos, Cars, Trucks, Boats, Motorcycles Online Classified Ads - AutoTrader.ca
Any comments or input would be greatly appericated thanks!
p.s i know the ad at the top says 2006 f-150 but that's just a misprint.
Old Apr 24, 2008 | 07:01 PM
SICKS-O's Avatar
SICKS-O
link doesnt work but if its an 06 with the diesel option its a 6.0L
Old Apr 24, 2008 | 07:59 PM
bigdieselrig
if the link dosen't work here it is again Canada Used Autos, Cars, Trucks, Boats, Motorcycles Online Classified Ads - AutoTrader.ca
Old Apr 24, 2008 | 08:02 PM
bismic's Avatar
bismic
If you are looking at used 6.0's here are a few considerations (along w/ the OASIS and CARFAX reports that are essential):
Some 6.0L weak points (things to check):
Look for signs of coolant degas bottle overflow (dry white residue on and around the degas bottle or no level in degas bottle).
Ball joints go out at 40k-70k miles.
Lots of idling can cause EGR problems. I look at the hours on the engine (if it has this monitored) and divide the miles by the hours (is it below 30? If so, may have had lots of idling).
EGR valves seem to plug quickly - maybe negotiate a new EGR valve.
Look for oil leaks - some trucks have had a lot of them
Try to find out about the routine maintenance:
Filter change intervals on time? What kind of oil (CI4+ or CJ4 - one of these is required)?
OEM filters? Look at them and see what kind they are. Aftermarket filters can cause MAJOR problems.
Find proof of Transmission being flushed - it is recommended every 30,00 miles.
Any exhaust problems visible (ie lots of white or blue smoke)? White smoke may mean an EGR cooler leak.
Check for any FLUID leaks (SPECIFICALLY OIL LEAKS - 6.0L are prone to many of these from many possible places!!)
CEL light on? Consider getting a code reader and check for DTC's.
If you can pull the EGR valve, I would do so and check for wetness or excess soot. Wetness indicates an EGR cooler leak.
The Electronic Shift on the Fly ESOF sometimes fails due to vacuum leaks. Be sure to check this out (several times in and out of 4WD).
Check for excessive wheel bearing wear (looseness) or ball joint looseness.
Check the coolant - it should have the Motorcraft Gold Coolant - anything else and there may be problems. Look in the "degas" bottle and inspect the fluid - it should be gold colored and there should be NO OIL visible.
Any evidence of a tuner (aftermarket air filter, gauges,etc). Tuners may or may not be bad. Some tuners are MURDER on the transmission. Some dealerships will cause you a lot of problems w/ them - even if you bought it that way used.
Aftermarket air systems could be a problem. Many of them (like K&N) do not filter well and could cause issues. Up to 500 hp, the stock air system is best!
Try to find out if the original owner ever ran it empty on fuel or have plugged filters?
Then the common stuff I'm sure you know:
Look at and smell the fluids. Make sure fluids not burnt, not too thick or dirty.
Drive it - surges? Stutters? Rattles or clunks? Good acceleration? sluggishness?
Check the tires - should have over half the life left at this mileage - abnormal wear?
How do the brakes look? Any pads need replacement? Are the rear brakes excessively worn?
All electronics working? Especially the AC?
Dents? Air bag been replaced, etc.
See if he has any repair or maintenance records.
Take off the price for windshield dings, paint chipped, torn upholstry, etc.
Does the truck look too clean? Does it look like the oil was just changed? May be hiding something.
Old Apr 24, 2008 | 08:35 PM
bigdieselrig
thanks for all the great info guys! i guess what my question really is what do you guys think is a fair price for this truck
Canada Used Autos, Cars, Trucks, Boats, Motorcycles Online Classified Ads - AutoTrader.ca ?
Old Apr 24, 2008 | 09:42 PM
bismic's Avatar
bismic
It would totally depend on what you found when investigating the list provided above.
Is it from a dealership or individual? Can you bargain for things like extended warranty's?
The most I would think it was worth - hmm. Look up Kelly's Blue book and NADA. Do not pay more than loan value in my mind. Offer several thousand less (even lower if problems are found).
Old Apr 24, 2008 | 11:09 PM
bigdieselrig
thanks bismic for all the great info and advice!
