Sponsored by: Auxito
key and tumbler help
Old Sep 8, 2001 | 04:28 PM
shenders's Avatar
shenders
I have a 89 f150 and I can't figure out how to replace a worn out key and tumbler.Book says turn key to run position and depress pin. What pin and how do i get to it. Pls help....i'm stuck at inlaws house Steve
Old Sep 8, 2001 | 06:18 PM
Torky's Avatar
Torky
To pull out the ignition cylinder, turn to run, and look underneath at the plastic shroud around the column. You are looking at the underside to see this. There are holes that have phillips head screws in them. One of those holes on the right side does not have a screw. Insert an awl or a long thin nail into that hole. You will feel some resistance, then it will "give". Then, while holding the pin in, wiggle the key and lock cylinder out together as a unit. Then pull out your tool. Put the new cylinder in with the key in it already, and the new one will snap in when wiggled in.
Be advised that a common problem with that vintage is that the relay rod from key cylinder to the actual ignition switch breaks, and is a common cause for thinking that the key cylinder is no good.
Old Sep 9, 2001 | 09:09 AM
jessetouhey's Avatar
jessetouhey
ben harpo
Feb 21, 2014 09:38 AM
mechelement
Dec 23, 2012 07:33 PM
jtindale
Sep 8, 2012 11:05 PM
jtindale
2004 - 2008 F150
Sep 8, 2012 10:01 PM
MatFrat
1983 - 2012 Ranger & B-Series
Sep 8, 2010 11:39 PM
