Ignition Switch / Tumbler
I went out to start my truck yesterday morning when it was 16*F outside. I felt the normal, POS tumbler resistance and then it spun freely until a stop which only allowed the glow plugs to glow. So I had to take the car to work.
Is there a specific procedure or write-up on how to replace these?
A Google search rendered:
Put key in ON position
Push thin nail through hole in column, under tumbler
While maintaining pressure with nail, pull tumbler directly out
Put new tumbler in ON position
Push new tumbler back into hole
Done
I have a feeling it's not that easy. Any specific lubrication?
Done
Received 3,101 Likes
on
****, I thought this was going to be a new tumbler swap. On the '86... Top of the column, meaning pull the wheel?
on
here is a writeup on it:
Ford Truck Enthusiasts Forums - View Single Post - help with ignition actuator
yup. it is about a 2-3 hour job.
I think this essentially the same with pictures and on a FSB: Ignition Actuator Replacement on an '85 w/tilt - FSB Forums
Edit:
Will engine assembly "white grease" work for lubricating the parts? The tube I have isn't really affected by the cold temps.
on
Got it done. I did break the middle, plastic shroud closest to the steering wheel. I used engine assembly grease on the actuator, every other sliding part and the ignition tumbler. I popped those bearings out and greased them. putting the spring in is the trick to the whole thing. Also, don't forget to reinstall the snap ring.
Thanks for the tips.
on
Timothy Moran
08-25-2017 12:12 PM
squirrel64
17
12-09-2013 07:59 PM
rmalottwtes30
02-25-2008 05:56 PM
