MBRP Installation
Old 04-24-2008, 01:52 PM
matttaubert's Avatar
matttaubert
matttaubert is offline
MBRP Installation
I purchased the MBRP turbo back system and have a question for anyone else that has this setup. The mid pipe which attaches directly to the down pipe has a welded on hangar rod that in my case does not have much of a hook type bend in it. There is a factory hangar mount where this rod is welded on but the rod does not really hook into it it just kind of slides in and does not appear to provide much support. Can anyone provide me with a picture of how the rod/hangar appears on there truck? Other than this I love the system and it sounds great but I don't think I have something right on the mid pipe.
Thanks for any help!!
Old 04-24-2008, 02:06 PM
big poppa's Avatar
big poppa
big poppa is offline
I got the same thing on my exhaust, hanger rod that goes straight. That one seems to be in the middle where the back door under the truck with a crew cab. Take a look at my gallery. The second album got the exhaust pictures in them. Take a look, if not i'll take a picture for you in a little bit.
Old 04-24-2008, 02:16 PM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
You have to use the same rubber grommets from the original exhaust. Put some lube on the rubber to slide the bracket off.
Old 04-24-2008, 04:31 PM
matttaubert
I realize that I need to use the grommets but the rod attached to the mid pipe appears like it should have some type of bend in it in order for it to fit nto the grommet.
Old 04-24-2008, 04:42 PM
miller_feed
I looked at mine and it is the same way. I think with all the clamps tight it cant go anywhere. It looks like it mostly just hold the pipe up.
Old 04-24-2008, 04:56 PM
big poppa's Avatar
big poppa
Like miller-feed said, tighten that clamp real good, i did. It won't go nowhere.
Old 04-24-2008, 05:17 PM
smdenlinger's Avatar
smdenlinger
smdenlinger is offline
I have the same exhaust and just to be sure I had it spot welded all the way back.
Old 04-24-2008, 07:32 PM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
I had the same head-scratching thought until I got the complete system installed. Just like Miller said.
Old 04-24-2008, 08:30 PM
medhvac's Avatar
medhvac
medhvac is offline
same here it will work!
Old 04-25-2008, 06:23 AM
matttaubert
Thanks for the replys I feel better knowing that I did not mess up installation.
