exhaust
Old Jan 2, 2002 | 04:17 PM
fordzrule's Avatar
fordzrule
exhaust
can the crossover tube on the back of the heads leak exhaust. ive replaced the gaskets on the collectors and on the heads but i cant stop the stupid leak
Old Jan 3, 2002 | 10:20 AM
Franklin2's Avatar
Franklin2
exhaust
Yes, these are famous for rusting out, especially if the smog pump has been disconnected. I made a solid gasket for the back of the heads, and used it to block it off.
Old Jan 3, 2002 | 04:10 PM
slikness's Avatar
slikness
exhaust
Ford sells the plugs for the back of the heads and they are fairly reasonable.
Old Jan 7, 2002 | 10:38 AM
yrlngproject's Avatar
yrlngproject
exhaust
slik, have you got P/N's for these smog tube covers? my dealers parts guys didn't know anything about them??\
gene:-X23
Old Jan 7, 2002 | 07:30 PM
Franklin2's Avatar
Franklin2
exhaust
I thought I heard somebody say they used regular drive in plugs like freeze plugs. But I would think these would be hard to get in with the engine installed. That's why I just made a block off gasket.
Old Jan 7, 2002 | 08:20 PM
Caddy 53's Avatar
Caddy 53
exhaust
If my memory serves me right that tube is held in place w/ couple hex bolts (5/16 ?). How about a flat plate bolted over hole w/gasket
CADDY 53 chuck centerburg oh
Old Jan 7, 2002 | 11:37 PM
slikness's Avatar
slikness
exhaust
I think I've still got a set in the original plastic bag with the P/N still on them. It will be tonight (Tuesday) before I can dig them out and I'll post the number.
Old Jan 8, 2002 | 01:10 PM
airharley's Avatar
airharley
exhaust
Why not use a steel allen head pipe plug? I did that on my 351W heads. Works really well. Plus you have a bonus of not having to cry shout and curse dealing with getting the socket on the back of the head.
Old Jan 8, 2002 | 02:24 PM
slikness's Avatar
slikness
exhaust
I tried to find plugs that worked, but, if they are the same air pipe holes that I have in the 351W heads, they are not pipethread. The size and thread are unique as far as I can tell.
Old Jan 8, 2002 | 06:25 PM
slikness's Avatar
slikness
exhaust
The plugs are called inserts and come in a package of 2. The numbers on the package are F4ZZ-6E086-A and H751B 021398. It is a course threaded plug about 3/4" long and the inside is threaded so that you can use the plug for a bolting something to the head. The front of the head probably already has these plugs in place.
Old Jan 9, 2002 | 10:21 AM
airharley's Avatar
airharley
exhaust
foreverfordtrucks
21
Jul 8, 2014 05:48 PM
Chilako
Sep 16, 2006 07:12 PM
armcan
Bronco II
Dec 9, 2003 11:46 PM
wcm444
Aug 11, 2003 07:44 AM
donhclark
May 23, 2003 01:11 PM
