update mechanics stumped
Old Jan 10, 2002 | 10:51 PM
am3ftlaud's Avatar
am3ftlaud
83 F-150 302/eec III ignition gets gas has no spark replaced all usual suspects comp, sensor, rotor, crank sensor, module. Next to the relay is another plug, female four holes, has a white w/red dot wire green w/black dot wire and two others I dont remember. The only time he got it to run was by bending a paperclip and connecting two line then shaking a test light back and forth inside this connection. Noone knows what this plugs into (another relay maybe???) any help on this or any other ideas would be greatly appreciated. Either here or email artmcg at bellsouth.net thank you ps im begining to think the truck would make a nic planter in the front yard because I cant afford 500 bucks tor a mallory systemwhich with my luck wouldnt work with the holley carb
Old Jan 11, 2002 | 09:06 PM
Caddy 53's Avatar
Caddy 53
Old Jan 11, 2002 | 09:20 PM
Caddy 53's Avatar
Caddy 53
I think NETSCAPE IS LAZY TONIGHT!!!!!!
I beleive that ignition is fed thru starter solinoid and it must have good housing to fender ground to work. Is there a fuse link that is burnt?
I would think that a ECC man at your dealer should have the answer.
Chuck Good Luck:-(
86f150step
Sep 23, 2013 07:21 PM
jmcder53
Electrical Systems/Wiring
Feb 9, 2010 06:04 PM
lewyk
Aug 16, 2009 07:55 AM
websthes
Sep 14, 2007 06:56 PM
fordtrk55
Aug 2, 2002 12:11 PM
