91 Explorer Center Console
Old Apr 23, 2008 | 02:07 PM
samahi72's Avatar
samahi72
How in the world do you remove the center console? Any pictures of all the bolts and screws that need to be removed?
Old Apr 24, 2008 | 11:05 AM
loudfords's Avatar
loudfords
Took one out of a 93 last night. It's easier to remove with seats out of the way, but should be possible with them left in.
1. Pop out oval shaped caps at top rear sides of console. Behind these caps are 2 bolts on each side that take an 8mm socket. When these bolts are out, you can lift out the arm rest.
2. Remove 4 phillips head screws in cupholder, and remove cupholder.
3. Under cup holder are 2 phillips head screws in that hold the front of the console. Remove these, and 1 at the top where the arm rest came out. Now you should be able to remove console.
4. The mounting brackets are held to the floor by nuts that take 10mm socket, 2 on the front bracket, 4 on the rear bracket.
Hope this helps.
Old Apr 24, 2008 | 06:36 PM
samahi72's Avatar
samahi72
perfect information. Came right out once I knew what screws and bolts to remove. Thank you.
1ole4d
Mar 1, 2017 08:26 PM
Rwloope
Feb 20, 2016 06:04 AM
Mgray770
Escape & Escape Hybrid
Dec 18, 2014 07:34 PM
ufvj217
Aug 31, 2012 06:26 AM
GIZZYFORD
Feb 27, 2012 03:37 PM
