vibrates at all speeds
Old Apr 23, 2008 | 09:14 AM
scrappy115's Avatar
scrappy115
I have a 02 Explorer and it started to vibrate at all speeds and then stoped for a while then started again. Any Ideas why????
Old Apr 23, 2008 | 12:58 PM
scrappy115's Avatar
scrappy115
i had this checked out and was told it is the cvu joints on the back axle. does that sound right????
Old Apr 23, 2008 | 05:05 PM
steve(ill)'s Avatar
steve(ill)
well a CV joint going bad can cause a vibration, but i have never heard of a CV joint going bad in the newer EXP. I guess it is possible. I would have thought it was a tire or drive shaft universal joint, or wheel bearing. You should have noise if it is a bearing. Tire problems would be the first guess if no sugnificant noise.
Old Apr 24, 2008 | 09:57 AM
scrappy115's Avatar
scrappy115
Thanks! I'll take it some where else to get checked. I just put new tires on it about 4 months ago.
Old Apr 24, 2008 | 08:27 PM
99f350sd's Avatar
99f350sd
Be sure to check the back of the wheels for dirt,mud etc. That is if you live on dirt roads like I do..
Dick
