Looking for help on Engine ID
Old Apr 23, 2008 | 09:54 AM
namdorf's Avatar
namdorf
Bought a 1967 Ford p/u 1/2 ton, trying to figure out the engine. I know it is obviously a 6 cyl , but is it a 300 cid or did they put them in them back then? Any help would be appreciated.
Tim
Old Apr 23, 2008 | 11:13 AM
gnwalker's Avatar
gnwalker
could be a 240 or 300, someone will chime in and know how to get a definate answer
Old Apr 23, 2008 | 10:15 PM
namdorf's Avatar
namdorf
I thought it was a 300, but someone else told me it is a 240. hopefully somebody can help or at least tell me where to look on the engine for any ID numbers.
Thanks Tim
Old Apr 23, 2008 | 10:48 PM
85e150's Avatar
85e150
VIN and/or door plate will have the codes. Numberdummy can decode for you if he stops in after you post.
Or, pull a plug and measure with a piece of wire by sticking the wire in a tdc and bdc and measuring the stroke. 3 1/2" = 240, 4" = 300.
Old Apr 23, 2008 | 11:17 PM
namdorf's Avatar
namdorf
Ok I will try to get the VIN tomorrow!
Thanks Tim
Old Apr 24, 2008 | 10:25 AM
sub44ofrd's Avatar
sub44ofrd
VIN if the 4th digit is "A" it's a 240
if it's a "B" then it's a 300
*1 240 Low compression
*2 300 Low compression
Old Apr 24, 2008 | 10:43 PM
namdorf's Avatar
namdorf
Fourth digit is an "A" so it looks like a 240. Is this engine worthy of keeping or should I be looking to upgrade to a 300 or possibly " biting the bullet" and dropping a 302 in it?
The motor still runs good, I am just looking for some input.... good or bad on these motors.
Thanks Tim
Old Apr 25, 2008 | 07:36 AM
sub44ofrd's Avatar
sub44ofrd
Switching out engine is personal choice. If it's not broke I say don't fix it. Depends though, I left in my stock 300 because I'm all about stock.
What are you looking to do with it, if you're gonna restore it and make it a beauty queen then leave it be, if you're gonna use it for haulin, towin, beatin ect then drop in an 8!
As far as is it a good engine...in my opinion all cast iron dinosaurs are worthy of keeping if for the right purpose...not really a whole lot to go wrong on them like the new garbage.
Old Apr 25, 2008 | 12:12 PM
mcdobson's Avatar
mcdobson
Remember on a forty year old truck anything could have been changed.
Your VIN will tell you what the truck came with not necessarily what is in it now. Check casting numbers (not sure where they are on 6's) or check the stroke as suggested before.
