Water pump housing
Old Jan 14, 2002 | 07:11 PM
jmacjr1125's Avatar
jmacjr1125
Water pump housing
I have a 70 302 and there is a housing between the water pump and the main engine block that I need to replace.What is it called?
Old Jan 14, 2002 | 08:29 PM
airharley's Avatar
airharley
Water pump housing
It's the timing chain cover/housing. If you need to replace it look in the local junkyards first. Ford charges an arm and a leg for them. SOme where in the range of $90.00 down here in LA.
Old Jan 14, 2002 | 08:41 PM
airharley's Avatar
airharley
Water pump housing
