Head Gaskets
Old Jan 13, 2002 | 05:32 PM
ExplicitHP's Avatar
ExplicitHP
Post Head Gaskets
I got a good deal on a set of Mr. Gasket #5751 Solicor head gaskets for my 351. Are these decent gaskets? They are regular gasket material except for a steel ring around each cylinder. I am only running 8.5:1 compression but i plan on installing a supercharger. How would these gaskets hold up to a supercharged engine? Or how about an un-supercharged engine with a 75HP shot of nitrous? Al i better off with steel gaskets?
-Jon
Old Jan 14, 2002 | 08:41 PM
airharley's Avatar
airharley
Head Gaskets
Every tech article I have read has always use head studs, main cap studs, and graphite head gaskets. I know Clevite sells them under the McCord brand name. Same with Fel-Pro. These are your best bet. There are also the "O" ring gaskets you can buy but you will end up machining your heads or block for them.
Old Jan 15, 2002 | 01:47 AM
lvstang's Avatar
lvstang
Head Gaskets
