Whistling noise in engine compartment???
Old 04-23-2008, 08:41 AM
tttario's Avatar
tttario
tttario is offline
I am getting a whistling noise from inside my engine compartment. I searched here and took some of the info and inspected my headers and up pipe to look for cracks but everything seemed OK. I am thinking a vacuum hose maybe. Where do I look for these? THe sound seems to happen only under small to moderate load and comes in short pulsing bursts while accelerating or during deceleration.
Any help please???????
125,000 km's
Old 04-23-2008, 08:58 AM
jmaskew's Avatar
jmaskew
jmaskew is offline
Do you see any coolant drops around the degaus bottle? Also, I sometimes get a whistling noise when I extend my mirrors out when the air hits it just right, it's not real loud just annoying if you have the window rolled down. I thought it was the dreaded "tea pot" whistle due to head gaskets but the whistle goes away when I push the mirrors in.
Old 04-23-2008, 09:04 AM
redneckrex's Avatar
redneckrex
redneckrex is offline
is it the trans cooler fan? or the fan clutch kickin in when its warm?
Old 04-23-2008, 09:59 AM
tttario's Avatar
tttario
tttario is offline
Might be the head gaskets? Anyway to check for sure?
I would have expected the whistle at full load as well for the gaskets to be blown......
Old 04-23-2008, 10:05 AM
tttario's Avatar
tttario
tttario is offline
Just checked and there are drip marks running down the degas bottle. They are dried up enough I can not rub them off. Coolant level seems a little low as well.
Old 04-23-2008, 10:18 AM
jmaskew's Avatar
jmaskew
jmaskew is offline
When my gaskets blew my truck would defuel due to overheating while towing 4500lbs. Empty, it would run hot, fan would come on sometimes, plus you could smell coolant while stopped. There were water dropplets around the outside of the degaus bottle... it never "puked" coolant like other people have experienced. I was loosing coolant in the degaus bottle and would have to add a half gallon every once in a while until it was fixed. Hope this helps.
Old 04-23-2008, 10:21 AM
jmaskew's Avatar
jmaskew
jmaskew is offline
It sounds like the head gaskets. I would look into the extended warranty that people have been talking about on here. It will cost a lot less than paying for the gaskets out of pocket. It's worth a try.
Old 04-23-2008, 10:28 AM
tttario's Avatar
tttario
tttario is offline
I have the extended warrenty. I'll bring it in and have them take a look. I was just trying to save $100 hoping it was a vac line.
Any other comments???
Old 04-23-2008, 11:11 AM
BowTieHatr's Avatar
BowTieHatr
BowTieHatr is offline
its not a vacuum line. not enough volume from the pump. more than likely it is the egr up pipe being a 05. done several of these.
Old 04-23-2008, 11:46 AM
tttario's Avatar
tttario
tttario is offline
I have the EGR disconnected right now and since I bought it 20,000km's ago. The fact that it is in the exhaust stream will my MBRP with cat and muff in cause any warrenty issues???
Old 04-23-2008, 11:55 AM
tttario's Avatar
tttario
tttario is offline
Just went for a ride
So I just unscrewed the degas cap and there was alot of pressure in there. Put cap back on and went for a ride. Whistling gone for first little while and then came back after 10-15 min. I think the whistling is coming from the degas overpressurizing.
If it is the EGR up pipe, should I plug it back in before bringing it in or does it matter for warrenty????
Old 04-23-2008, 11:57 AM
jmaskew's Avatar
jmaskew
jmaskew is offline
Can a blown egr cooler cause headgaskets to blow in any way? When my egr cooler failed it sent the Water Temp gauge to about 3/4 on the stock gauge. Can overheating cause the gaskets to fail or weaken? The tech checked my heads and they were not warped. Thank you.
Old 04-23-2008, 01:51 PM
BowTieHatr's Avatar
BowTieHatr
it could be the cooling system causing this but i since you say small load, it tough to say. however it could be heads/gaskets causing the excess pressure causing the whistle.
highly doubt it. heads can cause a egr cooler to fail though.
Old 05-07-2008, 02:00 PM
tttario's Avatar
tttario
tttario is offline
Just heard back from dealership. Head Gaskets are fried. Tried to weasle in a set of ARP's but no luck.
Just letting ya know.
SCT is coming and staying out.
Old 05-07-2008, 05:08 PM
MeyerzF350's Avatar
MeyerzF350
MeyerzF350 is offline
I just had my head gaskets replaced and the EGR cooler. The whistle is louder than ever now.
Restlesswildman
06-18-2015 09:49 PM
billbot
02-17-2015 09:55 PM
andybear5014
12-08-2013 09:49 PM
mattparham1
09-23-2013 06:33 PM
bhaider
10-15-2004 12:45 AM
Quick Reply: Whistling noise in engine compartment???
