Ford Highboy???
Old Jun 27, 2013 | 08:57 PM
Nseal1996's Avatar
Nseal1996
Originally Posted by 704 dentside man
That's a dummy door...can't remember why Ford did it...but I only recall it being on 77's.
My 75 Highboy has a gas tank on the bed also along with the in cab gas tank. The bed is not swapped all factory. But while the gas door is factory the gas tank that sits there is definitely not
Old Jun 27, 2013 | 11:43 PM
Duckmang's Avatar
Duckmang
My 75 also has the fuel door opening in the driver's side near the rear of the bed. No tank or anything underneath, and no trim or anything at the opening. Been wondering whats up with that myself.
Old Jun 28, 2013 | 01:37 PM
montana_highboy's Avatar
montana_highboy
'73-'76 highboys had the round block off plate, or 'plug' if you will.
'77 highboys had the square fuel door, though it too led to nowhere, it was just a 'dummy' door.
Old Jun 28, 2013 | 01:45 PM
rogue40's Avatar
rogue40
After 60 Minutes did the exploding cab bit in 75 or 76 the big push was on to put the tank outside. They had the bed designed and in production before they got approval(from the DOT I believe) for the tank design and to locate it in the back.
As was standard policy with Ford, they used whatever bed they had.
My 77 is actually post a 77.5 Custom and came stock with the dual tanks/toolbox/400/4spd/married transfer case and sits comfortably closer to the ground than the pre 77.5. (Yes I am getting old)
I just found the right bed for it after about two years of searching. I now consider that to bethe Holy Grail of Ford pickup beds.
WW2N
Sep 18, 2016 05:27 PM
86-03Ford
Sep 7, 2016 09:05 AM
WhatsAChevy?
Oct 4, 2015 02:50 PM
Obowersox26
May 10, 2015 02:58 PM
91dirtydiesel
Oct 9, 2009 05:00 AM
