friction additive
Old Apr 22, 2008 | 08:29 PM
96powerstroke's Avatar
96powerstroke
friction additive
just serviced both the front and rear dif on my o2 f350. does either one, the front or rear need friction additive. in the rear i am going to run lucas synthetic 75w-140 and it says no additives need on the bottle. in the front i will be running 75w-90 amalie synthetic. whats the verdict on friction modifier additive?
Old Apr 22, 2008 | 08:32 PM
F350-6's Avatar
F350-6
A friction modifier is needed on limited slip diffs. Some lubricants already have a friction modifier built in so there's no need to add any.
I don't know about the lucas, but if you hear chatter in the turns you need to add a modifier. If not then leave it alone.
Old Apr 22, 2008 | 08:36 PM
96powerstroke
ok, what is the ration of modifier to gear oil?
Old Apr 22, 2008 | 08:38 PM
schlepprock250's Avatar
schlepprock250
I run Royal Purple in mine, it has the friction modfier already in there so you dont have to add any.
Old Apr 22, 2008 | 08:41 PM
F350-6's Avatar
F350-6
The spec calls for 8 oz., but it's best to add 4 oz if needed and bump it up as needed to get rid of the chatter. The LS works better without too much modifier in there.
Old Apr 22, 2008 | 08:43 PM
F350-6's Avatar
F350-6
Royal purple was the one I was thinking of that does not need the additive. Lots of folks here swear by the stuff.
Old Apr 22, 2008 | 11:30 PM
Neil64's Avatar
Neil64
Mobile 1 Synthetic
I had mine changed with Mobile 1 Synthetic which contains the friction modifier, per their label. Well, my rear chattered. Added 4oz and it cured 85%. Added another 4oz bottle and the rear seems OK. Every now and then I perceive chatter. Limited slip seems to work fine too.
Neil
rogerranger2122
1983 - 2012 Ranger & B-Series
Oct 9, 2016 04:49 PM
whomrig
1997 - 2003 F150
May 29, 2016 09:55 PM
Louie3
1997 - 2003 F150
Feb 27, 2012 08:34 PM
DRM2004
2004 - 2008 F150
Jul 25, 2009 09:48 PM
deano2
Oil & Lubrication
Apr 1, 2005 07:03 PM
