instrument dash lights
Old Apr 22, 2008 | 10:55 AM
cps's Avatar
cps
Could anyone tell me the sequence to get at the lights in the instrument panel and if i need any special tools? thanks, Roy.
Old Apr 22, 2008 | 11:25 AM
just another truck's Avatar
just another truck
From what I have read, it is all one assembly..Instructions read, disconnect battery cable, tilt steering wheel to lowest position, remove instrument cluster finish panel ( remove radio, loosen two screws in radio opening, use screw driver to carefully detach bezel retaining clips, pull bezel back, disconnect electrical connectors and remove bezel from vehical) pull the instrument cluster oput and unplug the electrical connectors from the back side, then remove cluster from instrument panel, on automatic transmission models, detach transmission range indicator.
Good Luck.
Old Apr 22, 2008 | 02:24 PM
F350-6's Avatar
F350-6
It's easy to do Roy. As Pat described remove the radio. You can get a set of U shaped Ford radio removal clips from the auto parts store for less than $5. They slide in the holes on the radio and you just pull the radio out.
There are 2 phillips head screws above the radio you may want to loosen (I always forget to loosen mine, but it's a good idea) Then the upper portion of your dash panel just unsnaps. Disconnect the plugs on the back of the headlight switch, cigar lighter, & air bag key & just set the dash aside.
From there you'll see the 4 screws holding the instrument cluster in place. Remove the screws, flip the cluster over and you'll see where the bulbs plug into the back.
Old Apr 22, 2008 | 06:03 PM
cps's Avatar
cps
Thanks for the info. Will tackle this tomorrow.
roy123
Jan 5, 2012 06:32 PM
Sailor Roy
6.7L Power Stroke Diesel
Nov 7, 2011 01:38 PM
caspermj
Oct 27, 2008 04:15 PM
Roy in TX
Oct 10, 2006 04:54 PM
Captain Roy
1997 - 2003 F150
Dec 21, 1999 11:18 PM
