cold idle problem
If I drive away cold, the engine will pulse when I idle. Like, if I roll up to a stop sign, the engine will surge or pulse about once a second, and my vacuum will be really crappy, like 13 or 15 inches. There is a slight hesitation when I take off from the line, like the truck is going to die. Then it picks up.
After about 2 miles, the truck starts to warm up and the idle goes all warm and fuzzy. When I got home friday (it was about 70 degrees outside) the einge was nice and warm. I pulled into the driveway and the engine was purring with a failry low idle and sitting at 20 incches of vacuum.
I am suspecting the IAC or the engine temperature sensor. I don't really know why the IAC would care what temperature I am at (seems like it would work poorly no matter what it if was cruddy). I replaced the IAC last summer. I am planning on cleaning it, but I really don't think the symptoms fit that bill.
Does anyone else know what I should try? I have checked my vacuum lines. They are all new, even the lines on the TB and the line back to the tranny. I replaced my upper intake gasket and my TB gasket the other day, so they are fine. The fact that I can get the 20 inches of vaccum when the engine is warm makes me think it's not a vacuum leak.
Any ideas?
I noticed that my injector for #2 (the front driver's side) cylinder is clicking pretty loudly. I probed it with a scrwdriver and there seems to be more mechanical noise on it than the others on the dirvers side. Is that normal?
