MPG's Revisited...AGAIN
Old Apr 22, 2008 | 01:04 AM
Technitom's Avatar
Technitom
Veteran: Navy
Lightbulb MPG's Revisited...AGAIN
OK guys
I'm doing some comparisons so I need accurate data from you (NO BS)
this is NOT a competition, so zipp your pants back up... LOL
I want to know ALL of the following:
what mpg's are you getting?
what year truck?
what is your driving style? (granny? average? spirited? WOT?)
what sizes tires are you running? (MT? AT? HWY?)
what is your gear ratio?
what transmission? Auto/manual
what is your current PCM flash code? (sticker on side of your brain box)
or are you running a chip or tune? what setting?
I would like to know what mods you have as well, even if its in your signature.....
if I can get this data, I will put it into a spreadsheet...
I have a several suspicions... one is that some of the older factory tunes are better than current.
I would also like to take the data and give it back in a more comprehensive form, what tune / tire / mod combos seems to work the best consistantly.
what's killing mpg's, what to avoid, etc...
SO HELP ME HELP US ALL!!
**NOTE**
I'm willing to do the work, but please give me all or as much data as you can in one post... I'd rather wait for all the data then get some, part, bits, & pieces scattered all over the place...
THANKS
Old Apr 22, 2008 | 06:06 AM
bdrummonds's Avatar
bdrummonds
1.what mpg's are you getting?
2.what year truck?
3.what is your driving style? (granny? average? spirited? WOT?)
4.what sizes tires are you running? (MT? AT? HWY?)
5.what is your gear ratio?
6.what transmission? Auto/manual
7.what is your current PCM flash code? (sticker on side of your brain box)
8.
1. 15.6 Mpg hand calculated
2. 99.5, build date of May 13 1999
3. average
4. 305/70/16 Hankook Dynapro MT's at 55PSI
5. 3.73
6. auto
7. Tuning by DP tuner, live tuned. original code is NVK3
8. Fuel bowl delete, FASS 95GPH pump,in tank mods, DP tuner live, van turbo(1.15 A/R), ATS compressor housing, 6.0 Intercooler,AFE Pro Guard 5 big boost filter,SS HPXover, 2 1/2" lift back and front, guages, Over boost regulator.
Old Apr 22, 2008 | 07:45 AM
F350-6's Avatar
F350-6
Empty mixed hwy city 60/40 19.7 MPG
what year truck?
2002
Grandpa
285/75-16 AT
3.73 LS
Manual
No tunes. I'll have to try and look for the sticker later
Mods 6637 & CCV. I did the 6637 the same time I switched over to ULSD so any gains were offset by the new fuel. I used to average 19.8 with the stock box & no CCV on LSD if you want to factor that in to your spreadsheet.
Mileage has been pretty consistent since break in.
Old Apr 22, 2008 | 08:56 AM
just another truck's Avatar
just another truck
what mpg's are you getting? 12.75 city
what year truck? 1999
what is your driving style? (granny? average? spirited? WOT?) average
what sizes tires are you running? (MT? AT? HWY?) 315/75/16 AT
what is your gear ratio? 373
what transmission? Auto/manual Auto
or are you running a chip or tune? what setting? Hypertech 3 100hp
I know you didnt ask, but
LB CC
Old Apr 22, 2008 | 09:11 AM
bdrummonds's Avatar
bdrummonds
Oh Yeah, I have dual ccv mod (to atmosphere). CC SB 4X4
Old Apr 22, 2008 | 09:17 AM
rbaker6336's Avatar
rbaker6336
what mpg's are you getting?16.5 highway -18 at 60-15.5 city
what year truck? 2000
what is your driving style? (granny? average? spirited? WOT?)slowish/standard
what sizes tires are you running? (MT? AT? HWY?)235/85/16
what is your gear ratio?4:10
or are you running a chip or tune? what setting? DP Tuner 40T city/80E
hand calculated
Old Apr 22, 2008 | 09:25 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>
what mpg's are you getting? An amazing 22 city last tank, best hwy 24
what year truck? 1999.5
what is your driving style? somewhere between granny and average
what sizes tires are you running? Stock
what is your gear ratio? 3.73
what transmission? Junk 4R100
what is your current PCM flash code? Superchip 80, but not much longer
</TD></TR></TBODY></TABLE>
Old Apr 22, 2008 | 09:29 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
what mpg's are you getting? 13.7 city 15.6 hw
what year truck? 2001
what is your driving style? (granny? average? spirited? WOT?) spirited
what sizes tires are you running? (MT? AT? HWY?) 265 75R MT
what is your gear ratio? 4.10 LS
or are you running a chip or tune? what setting? I will get back to you on the flash code. DP-TUNER DD 80e and 140 smoke.
Glad you are doing this.
Old Apr 22, 2008 | 09:46 AM
Markadeck's Avatar
Markadeck
If the creek don't rise, Friday a week I'm going to do a very interesting experiment. I'm driving down to Jody and Dianes. I will fill up very carefully upon leaving Charlotte and do the same when I reach Hoschton. Then after they do their magic tricks I will fill up very carefully at the same 2 places on my way back. Will post the results.
Old Apr 22, 2008 | 09:57 AM
Ponyboychris's Avatar
Ponyboychris
what mpg's are you getting? 15.5 City 17 highway - hand calculated
what year truck? 2002
what is your driving style? (granny? average? spirited? WOT?) Average
what sizes tires are you running? (MT? AT? HWY?) AT 235/85/16
what is your gear ratio? 3.73 non slip
what transmission? Auto/manual BTS Auto
what is your current PCM flash code? (sticker on side of your brain box) Stock flash
or are you running a chip or tune? what setting? Not yet
Other mods: AIS intake, AIH delete, zoodad, MBRP 4" exhaust turbo-back with muffler, CC SRW, LWB, 4x4 and as mentioned above, BTS Auto tranny.
Old Apr 22, 2008 | 10:05 AM
miller_feed
I don't care how careful you fill up, you will not match the mpg as going there. Going from superchip to DP-TUNER, you will have such a huge grin on your face that will go all the way down to your foot on the go pedal. It took me a couple months to start to get my mpg to start up again.
You always talk about how old you are getting, but I think you will find the TUNER OF YOUTH at Jody's place.
Good luck on the trip and keep us informed. Sorry.
Old Apr 22, 2008 | 10:12 AM
jwhitetail's Avatar
jwhitetail
Markadeck is your truck 2wd
Old Apr 22, 2008 | 10:14 AM
Markadeck's Avatar
Markadeck
I've already taken that into consideration. Jody is 10 miles off of I-85, I will fill up on the interstate before I get off, and then play with my new toy on my way back to the same truck stop and continue with my conservative driving back to my original fill up point at the Northern end of my little trip.
this thread has sort of been
Old Apr 22, 2008 | 10:21 AM
indebt's Avatar
indebt
1.what mpg's are you getting? = 13.2 CITY/ 17.6HGWY
2.what year truck? = 2000
3.what is your driving style? (granny? average? spirited? WOT?) = AVERAGE
4.what sizes tires are you running? (MT? AT? HWY?) = 325/60/18 AT TERRA GRAPLERS
5.what is your gear ratio? = 3.73
6.what transmission? Auto/manual = AUTO
or are you running a chip or tune? what setting? = DP 80 ECONO 99%
8. MODS = 1.0 TURBINE, WW, 6637, ZOODAD, 4IN TURBO BACK EXHAUST, 6.0 IC, TRU-COOL, 4IN LIFT, 2WD, AND I RUN 80 ECONO PRETTY MUCH ALWAYS
Old Apr 22, 2008 | 10:28 AM
Markadeck's Avatar
Markadeck
Yes, for sure. I could have bought a 4 x 4 at the same time and place, but have been through my years of playing with stuff like that and opted for the best truck money could buy at the time and get good mpg at the same time. I apologize to the initiator of this thread for letting it drift so badly. I should have started my own with the topic of my upcoming experiment. Can a mod figure out how to move this section of it?
