I pour water in the cowl and I have a small stream coming from the e break area way up in the corner. The truck is pretty rust free so I doubt its a rust issue. Any ideas? Thanks
Ok...so I removed the inner fender and I cant see nothing. The cowl drain is to far up between the fender to even get my hand up there. Also today I put the garden hose right over the cowl vent for about 5 min. and both the pass. And driver side seems to be draining just fine but I'm still getting a small stream of water inside the cab. I think its beggen for a forsale sign.
