302 id
Old Jan 30, 2002 | 08:08 PM
my275's Avatar
my275
302 id
I have a 302 short block and heads. I got it from a kid who had a machine shop build put the block and heads together. He was building an english car but got smart and gave up.
Looks like they did a good job on the block and head. I am going to put it in my 78 f150. My problem is not sure what year it is and I need a flywheel for it. Here are the numbers off the castings.
Block
C80E-6O15A
head top
302 2v
head bottom
C80E
Can anyone tell me anything about it?
Old Jan 30, 2002 | 08:14 PM
redneckdieselmechanic's Avatar
302 id
I think its a 81 to 86 302 block. Probably out of a F 100 or 150. Be sure to check the clearances and torque values. You can find flywheels at the local junkyard and have them turned if its for a manual tranny. Be sure to use a new harmonic balancer to eliminate bad vibes.
Old Jan 30, 2002 | 09:20 PM
Franklin2's Avatar
Franklin2
302 id
1960's start with a C
70's start with a D
80's with a E
Looks like a 1968 to me.
Old Jan 30, 2002 | 10:02 PM
airharley's Avatar
airharley
302 id
Look under "need help identifing block". I posted a web site address that has all the block codes from 64-95. You should be able to find what you are looking for.
Old Jan 31, 2002 | 08:00 AM
slikness's Avatar
slikness
302 id
