Sponsored by: Real Truck
Window wont go down
Old Apr 21, 2008 | 03:00 PM
RckyMntnKng's Avatar
RckyMntnKng
Window wont go down
Guys, on my 01 F350 I noticed the rear driver power window will not move, sputter, make a noise or anything. The lock is not engaged etc.
Where should I look first? I assume its either in the switch (but probably not becuase both the front and rear switch would have to bad) or the window motor. Is there any common problem areas so look at first?
Thanks!
-RMK
Old Apr 21, 2008 | 03:34 PM
elmo8641's Avatar
elmo8641
take the door pannel off then plug in the window switch. unplug the motor and put a multi meter. 1 probe on each wire. use the switch. you should have 12v one way and -12v's going the other. if you have voltage then the motor is bad. try that out then let me know. i will pull the wire diagrams and send them to you with what to test and where
Old Apr 21, 2008 | 04:05 PM
RckyMntnKng
Thanks, I will pull the panel and check for +12 and -12 and post my results
btm991
6.7L Power Stroke Diesel
Oct 21, 2011 04:11 PM
kemerick
Dec 28, 2005 08:04 AM
mds01
1978 - 1996 Big Bronco
Apr 6, 2004 11:24 PM
Castoff52
16
May 22, 2003 10:57 AM
Supercab
Apr 13, 2003 12:29 PM
