long crank time/hard start kinda!
Old 04-21-2008, 09:05 AM
fordboy2's Avatar
fordboy2
fordboy2 is offline
Lately I have been noticing a longer than normal crank time when the truck is cold. THe weather is about 40-50 degrees outside. Normal crank time I would guess to be 2-4 seconds and this would be about 10-15 maybe even a little more a couple of times. Looking for suggestions on what to check, I am thinking maybe the glow plug relay module located on the passenger valve cover. Could it be a glow plug? The truck is in my sig below, thanks in advance for any help, Aaron
Old 04-21-2008, 11:33 AM
BowTieHatr's Avatar
BowTieHatr
BowTieHatr is offline
do you have the latest reprogram?
Old 04-21-2008, 01:31 PM
fordboy2's Avatar
fordboy2
fordboy2 is offline
THe truck was updated last fall in around oct.
Old 04-21-2008, 04:43 PM
Living Proof's Avatar
Living Proof
Living Proof is offline
Mine was doing the same thing and I replaced the batteries, maybe you have a bad battery? just a suggestion.
Old 04-21-2008, 09:08 PM
fordboy2's Avatar
fordboy2
fordboy2 is offline
both batteries were new in december, not to say that may not be it but it cranks fine, just does not fire right away.
Old 04-21-2008, 11:57 PM
caycebugs's Avatar
caycebugs
caycebugs is offline
My 05 F250 was doing that last year. My dealer reflashed it and I have had no more problems. With the new flash, the injectors cycle for 30 seconds after switching the engine off. If yours does not cycle, you can definately hear it, you may need reflashed.
Old 04-22-2008, 07:47 AM
fordboy2's Avatar
fordboy2
fordboy2 is offline
I will check on if the injectors cycle, how much to have a reflash done? This morning it was about 60some degrees and it fired right up.
Old 04-22-2008, 08:39 AM
69cj's Avatar
69cj
69cj is offline
To Caycabugs,
You do not have the latest flash. The latest is the induction flash and it also varies the turbo and shuts down the egr during extended idling.
Old 04-22-2008, 09:05 AM
fordboy2's Avatar
fordboy2
fordboy2 is offline
could I have the latest flash since mine was updated in oct of 07?
Old 04-22-2008, 10:52 PM
hott-rodd's Avatar
hott-rodd
hott-rodd is offline
Are you guys still getting low power and poor fuel mpg from the new flashes?
Old 04-23-2008, 06:28 PM
DStairs's Avatar
DStairs
DStairs is offline
Long crank time
I just bought my 06 f250. It had a bad injector and I had it fixed. It still takes quite a while to fire up. It cranks fine, just takes a while to start. I live in central Ca. so the climate is not the issue.
Old 04-23-2008, 08:00 PM
bismic's Avatar
bismic
bismic is online now
Received 2,616 Likes on 1,819 Posts
EDIT - 69CJ has this covered (I missed it in the first pass).
The new flashes are GREAT in my opinion. My mileage improved as far as I can tell. The only thing I have not heard is whether or not the 03's lose power from the flash. This was a definite complaint from previous flash updates.
Oct 07 flash probably included the Inductive Heating. If it didn't, you would hear the "buzz" of the injectors cycling (per caycebugs post) from the previous version flash.
