302 -points to electronic ignition
Old Feb 3, 2002 | 05:57 PM
gentle1's Avatar
gentle1
Post 302 -points to electronic ignition
74 302 changing from points to elec. ign. what do i have to add or change to accomadate this.what is a good brand?where to obtain it?thanks
Old Feb 3, 2002 | 11:17 PM
restorit's Avatar
restorit
While you can go the route of swapping in a Ford Duraspark (OEM) ignition system from a newer model truck, a cheaper and easier route may be to install a Pertronix ignition in place of your points. These are available from a number of different sources, and are widely popular in the vintage Mustang circles as they provide the accuracy and reliability of electronic ignition while retaining the stock distributor (with its stock appearance). I swapped one in several years ago to replace the points on my '70 351C Mach 1. Even with using a remanufactured distributor, new points, and a dwell meter to adjust them I never could get the engine to rev over 4000 rpm without stumbling. After the Pertronix upgrade, I can't believe how much smoother the engine runs, and it'll pull to 5500 rpm without missing a beat. Since then, I've also installed one on a 240 CID I6 in a loader at work. Same results - couldn't be happier. I'll never run points in ANYTHING as long as the electronic upgrade kits are available. They sell, on average, for around $70 and are very simple to install, replacing your points and condenser under the stock cap.
Old Feb 5, 2002 | 02:17 PM
gentle1's Avatar
gentle1
this pertronix kit mustbe the new rave have heard alot about it.thanks for the info. and i plan on trying it.will let you know how it goes.thanks
Old Feb 5, 2002 | 05:10 PM
Matt_W's Avatar
Matt_W
mitzache
Nov 6, 2015 10:11 PM
manning-2
Electrical Systems/Wiring
Aug 15, 2013 06:33 AM
dmc919
Feb 22, 2007 01:25 AM
with
13
Jan 21, 2004 10:51 AM
44dwarf
Sep 10, 2002 10:27 AM
