first off i wish i would have bought this chip 2yrs ago when i bought the truck its like driving a different truck, what i had before was good, the ts chip i didn't like, the dp blows them out of the water
now the ? i read some where to not start the truck in one of the tunes is this just for a cold start or for every start i've been doing it on every start and its getting kind of old
If your oil temp is up to operating range (180*) then its O.K. to start with a tune. If its a cold start , let the temps come up before switching from stock.
PS. Your little water temp guage in the dash does not mean your up to 180* oil temp. It can take another 10 miles or so for the oil to come to temp after the water does.
Brandon is right on. I like to start mine in stock then switch to a tune after the temps get up. I will have to admit that I have not always done this, but after talking with the guys at smoking they have changed my ways. Also, Jeremy(JTHarvery) reminded me not to switch the tunes under a load. Let off the pedal and then switch, give it a second or two to adjust then hammer down.
ok i was hoping it was that way i know the guages on the dash are just fancy idoit lights i drive easy until the temp guage is in normal range, actually i've been driving pretty easy all the time with fuel prices right know
i have the new guage switcher and it has a little dot next to the # and when it goes out the tune is loaded so i let off change tunes wait for dot to leave and then get back on it
Just some thought on ur temps !! If you have a trans temp gauge its reading and ur oil temps will be similar at lower end of the spectrum... Im not sure how accurate this is but its got 2 b close
I have heard the same on a really cold start.
For the most part I don't give it much thought, just crank her over. What do you guys think the pitfalls are when starting the truck with a tune.
According to what we learned from Jody during mine and Mikes Live tuning, starting a cold truck in a performance tune can raise the pressures in the heads (not combustion, but ICP) to dangerous levels. Why? Because the PCM will retard the timing(up to 27*) due to cold oil. Jody told us the absolute WORST thing you can do to a PSD is start it in a tune cold, and then go romp on it before the oil is up to temp. IOW dont race your neighbor out of the subdivision unless you have let your truck warm up first.
Well i guess i have to admit to starting up under a tune when cold. Guess I won't be doing that anymore. Thanks for all the info guys, you guys are so great sharing all you know with everyone.
So starting in a tune is ok, because there is no load, as long as you don't drive untill it's up to temp.
That's what I have been doing. I live in Minnesota, so six months of the year I **** away fuel warming up my truck.
