351w Questions
Old Jan 27, 2002 | 08:16 PM
Bull's Avatar
Bull
351w Questions
Old Feb 6, 2002 | 06:31 PM
donk's Avatar
donk
351w Questions
How can I tell what year my engine is. I just bought the truck its a 51 ford f1 with a 351w owner did not know. they installed a remote oil filter due to clearance proublems, is there a short filter that will work with this engine. Also they mounted the oil filter upsidedown bottom of filter is up is this allright or should I remount. Thanks.
Old Feb 6, 2002 | 06:44 PM
bluestang65's Avatar
bluestang65
351w Questions
Your filter should be just fine. The best way to find out what year motor you have is to find a casting number. For the block, it is on the passenger's side beside the starter. should be a long number beginning with C9__ or something like that usually four letters/numbers. There is also a casting on the bottom of the heads where they would meet the oil valley. You would hvae to have them off to see it, but it is also a four digit combo like: C9OE or D0OE if it was built before 1974. The codes are fairly simple to break down:
C9OE ~ C means 1960s and the 9 means the year (1969).
Decoding the casting number will give you an estimate of what year they were made, but it is not exact.
As for that oil filter, it should be fine upside down.
dave
Old Feb 7, 2002 | 07:40 AM
slikness's Avatar
slikness
351w Questions
Yeah, but it's a lot messier when you go to change it...and I aways like to fill my filter half full of oil when I put it back on...just to help the startup lubrication process...
Old Feb 9, 2002 | 03:04 PM
bluoval's Avatar
bluoval
Post 351w Questions
TRY USING A FRAM PH43. ORGINALLY USED ON DODGE 318'S, BUT IT IS HALF THE HEIGHT OF A PH-8 USED ON FORDS. ALSO, CONVERT THE FRAM NUMBER OVER TO A WICKS NUMBER. THE FILTER ELEMENT IS TWICE AS MUCH AS FOUND IN A FRAM FILTER.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
