Lower Trim
Old Apr 20, 2008 | 11:39 AM
zigzkidz's Avatar
zigzkidz
Lower Trim
I am wanting to put the lower black/chrome pieces and the fender pieces on my truck but it didnt come with them on how would i fasten them on?
Old Apr 20, 2008 | 12:55 PM
ri_truck_guy's Avatar
ri_truck_guy
They all fasten on with either bolts through the body panel, or large nylon clips that attach to studs on the body. You can buy the correct attachments through LMC. The large nylon clips can be riveted on the body in lieu of the factory studs. If you're also intersted in adding the over the wheel well trim, they attach using studs that push into barrel nuts that fit into drilled holes in the body panel. They are also available through LMC.
Old Apr 21, 2008 | 04:34 AM
srercrcr's Avatar
srercrcr
LMC rocks!!!!!!!!!!
