Transmission/Brake problems
Old Apr 19, 2008 | 04:26 PM
dmcenery's Avatar
dmcenery
I just serviced the Trans on 2006 4x4 lariat. During trying to locate the converter drain, the motor kicked 1 tim (short). After service I have no power brakes. Any sugestions on what/where to look for the problem?
Old Apr 19, 2008 | 04:38 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Welcome to the site!
When you say no powerbrakes, does that mean no power assistance? or does that mean that the brakes don't work... period?
If its the former, it will be the vacuum assist... try and find the line from the intake manifold to the brake master cylinder (I don't know where it is exactly on an 06 F150), and it would either be disconnected, or leaky. I would suggest the former, as you must have knocked it/pulled it off when working on the tranny
If you have no brakes at all... either you are out of fluid or its leaking somewhere. You will need to get a buddy and try and bleed them.
Anyhow, you can probably find more assistance here:
2004 - 2008 F150 - Ford Truck Enthusiasts Forums
Good luck
Old Apr 19, 2008 | 04:56 PM
dmcenery's Avatar
dmcenery
It's no power assist. I can't find the where the line conects. Could it have been blown off when the engine kicked? Is this the same vacuum that goes tho the modulator on the trans?
Thanks
Old Apr 19, 2008 | 05:59 PM
BigF350's Avatar
BigF350
FTE Emeritus
I will be honest, I don't know... I am not overly familiar with the 04+ F150
Try posting it here:
They should be able to help
Old Apr 21, 2008 | 11:14 AM
dmcenery's Avatar
dmcenery
Had it towed to the dealer. It's under the injectors. $350 to put it back on OW. They claim they have to remove the injectors.
GreggD
2009 - 2014 F150
Jan 26, 2024 05:56 PM
woodster69
New Member Introductions
Aug 29, 2014 11:11 PM
Gov33
Apr 5, 2002 03:51 PM
new_driver
Jun 10, 2001 08:09 AM
