Sponsored by: Real Truck
ABS Location
Old Apr 19, 2008 | 03:54 PM
TP83's Avatar
TP83
ABS Location
Need to find the abs sensor or harness for a 2002 f250 7.3l. Ive looked over the site and found lots of good link, unfortunatly where everyone said it was and including the instruction mine is no where to be found. anyone have any other suggestions? its is supposed to be under the drivers side battery but theres no wires anywhere under the box. Thanks.
Old Apr 19, 2008 | 04:48 PM
bpounds's Avatar
bpounds
The sensors would be in the front hubs I think. But since you mentioned the location under the battery then I think you are looking for the control module. If so, that should be easy to find because the brake fluid lines have to do through it. Trace the brake lines out of the master cylinder and see where they go. I hope that helps, but my experience is with later models so I'm not sure just where you will find it.Bill
Old Apr 19, 2008 | 08:40 PM
TP83's Avatar
TP83
yeah i found it took a good part of the day because it was completely hidden from the top and the plug looked different from the pictures but i got it all figured out and running. just need to learn how to calibrate it. Thanks for the input.
kabcpapc
1997 - 2003 F150
Jan 9, 2021 03:07 PM
bridgeman
Jun 16, 2008 06:22 AM
kawika
13
Jul 14, 2007 12:49 PM
stephen.osborne1
1997 - 2003 F150
Oct 4, 2006 06:42 AM
handrail
1983 - 2012 Ranger & B-Series
Dec 7, 2005 08:27 PM
