E-250 engine noise
Old Apr 19, 2008 | 03:15 PM
mike31's Avatar
mike31
E-250 engine noise
Ford Motor Company’s Technical Article: Ethanol/Methanol Fuel Blends:
Ford Motor Company vehicles should operate normally if the customer uses blends that contain no more than 10% ethanol or a blend that contains no more than 5% methanol with its necessary co-solvents and additives. If the methanol does not contain the necessary co-solvents & additives, it will damage the vehicle.
Gentlemen I would like as many opinions as possible on this subject.
I bought new a 99' E-250, From day one it had an engine noise that sounded like rods rattling or a chain rattling from the engine. It became louder as the engine became older it currently has 80,000 miles.
To date I have spent a small fortune trying to find the cause.
New Mass air flow,cleaned injectors,New intake manifold gasket,plugs,egr parts ,new computer,upgrade software,all new 02 sensors, coils,
Experts have said, standard engine noise,to piston slap.
I just started using 89 octane with 10% Ethanol and the noise completely went away. I am on my 3rd tank with no noise at all. before this I was afraid the engine was going to blow, the noise was getting really bad.
A mechanic said for $1000 He would replace my brake booster which has a vacuum leak per code this would also rid the engine of it,s noise.
Could it be the vacuum leak had the computer adjusted to max and I was getting a poor burn, which the higher octane now has a hotter burn bringing it back closer to normal? just a theory?
any thoughts please.
Old Apr 19, 2008 | 07:14 PM
mhg's Avatar
mhg
if this is the case then you woill be able to tell by
sealing off the vacuum line to the brake booster
will make it hard to stop but only done as a
temp. measure to test for the leak
Old Apr 19, 2008 | 08:36 PM
mike31's Avatar
mike31
I will do this, and thank you for the reply, do you think a booster vacuum leak would put the computer past it's fuel trim adjustments and caused a poor burn and the higher octane brought it back?
It would be really funny if I had a bad booster from day one and the computer and knock sensor just keep trying to adjust the fuel trim.
I seem to be getting close to an answer just would like to know for my own head. Thanks
Old Apr 20, 2008 | 07:42 PM
mhg's Avatar
mhg
with the computer controlled sys. any leak throws it off
any unmetered air is not allowed by the computer
crewzer
6.2L V8
38
Mar 15, 2019 04:06 PM
puddintank
Feb 6, 2018 10:16 PM
scottperkins
1997 - 2003 F150
Jun 29, 2016 10:33 PM
blueeyedfordguy
Alternative Fuels, Hybrids & Mileage
19
Apr 20, 2010 12:10 PM
48ATOY
17
Feb 13, 2006 08:11 PM
