4.10 rear end?
Old Apr 19, 2008 | 02:02 PM
GEugeneS's Avatar
GEugeneS
4.10 rear end?
I got some info off this forum about determining what rear end I have. It suggested there was a tag on the back of the housing on the driver side and from those codes to make the determination. I roll under mine and there is no tag on the driver side, but it looks like there may have been some time ago which broke off or was broken off. But on the passenger side there is a tag which says:
4.10 V2C34 UB
606775-5 LS
Does that mean anything? The 4.10 sound like the gear ratio, the the "LS" sounds like Limited Slip, but I haven't a clue.
Old Apr 19, 2008 | 02:05 PM
clintbonnie's Avatar
clintbonnie
You can check the sticker for axle code in your door jam.. If it is a 4-10 the code should be F2.
Old Apr 19, 2008 | 02:11 PM
GEugeneS's Avatar
GEugeneS
Thanks Clint - I'll check it out.
Old Apr 19, 2008 | 02:22 PM
GEugeneS's Avatar
GEugeneS
Door jam says axel "F2". Guess it's a 4-10 then. Does anyone out there know why the tag on the passenger side?
Old Apr 19, 2008 | 03:06 PM
rbaker6336's Avatar
rbaker6336
that's where the tag is on mine and several other Dana 80s I looked at
Old Apr 19, 2008 | 03:29 PM
GEugeneS's Avatar
GEugeneS
OK, I thought it was on the other side. Maybe "LS" does stand for limited slip then.
ScottInTexas
Jun 11, 2015 04:12 PM
DIYMechanic
Feb 7, 2011 02:20 AM
bghnkinf250
Jan 20, 2011 01:00 PM
rockdawg84
Nov 28, 2007 10:39 AM
69 F100 LWB
Apr 10, 2007 03:03 PM
