Zoodad Feedback
Old Apr 18, 2008 | 06:45 PM
tumbleweed2's Avatar
tumbleweed2
Zoodad Feedback
I promised myself I wouldent do it. Then one day my buddy was over and we both did it. The zoodad is done. Now that I cut a hole though the pannel, will irregular gusts of wind cause an overboost situation. Say I'm flying down the road with a load and a gusty head wind. Its goning to have varying pressure in the intake. Will this cause disturbance in milage, prematurly failing boost regualator (is there is such a thing)?
I do think it pulls cooler air than that off of the radiator.
Any comments or experiences????
thanks,
Ryan
Old Apr 18, 2008 | 06:59 PM
Lovin7.3's Avatar
Lovin7.3
It will never overboost your turbo. The turbo sucks air thru the filter. Its not a true ram air setup its just getting cooler air to your filter.
F350-6's Avatar
F350-6
I think you'll be fine. We would have read about all sorts of blown up stuff if that was really a concern.
Besides your engine compartment isn't a sealed unit. If too much air were to get under the hood for some reason it would just flow down past the motor and exit under the truck.
Old Apr 18, 2008 | 07:15 PM
Action4478's Avatar
Action4478
Do you have one of .....these..... ?
If not , you should be fine....
Old Apr 18, 2008 | 07:25 PM
F350-6's Avatar
F350-6
Thanks Rick. I needed that after a long day. It was funnier with the other threads putting it in context, but that never gets old.
Old Apr 18, 2008 | 07:26 PM
randomhero1172's Avatar
randomhero1172
Ya there is no way possible. You should be more worried about if this mod actually DOES ANYTHING. Im sure it brings a little cold air to the intake but the truck willnot act ANY different in a strong headwind, strong rain, or snow. Ive seen em all so far and no problems
Old Apr 18, 2008 | 07:42 PM
jdecker88's Avatar
jdecker88
Well you could always add a little spin to give you a little more Booosht
Old Apr 18, 2008 | 07:47 PM
F350-6's Avatar
F350-6
We're not making fun of you Ryan, just sharing some old jokes. As Joe pointed out. You have nothing to worry about. He's put it to the test for you, along with Justin and several others.
Old Apr 18, 2008 | 08:14 PM
Action4478's Avatar
Action4478
thanks,
Ryan
In all seriousness ( spelling) you can't give it too much....
Old Apr 18, 2008 | 09:18 PM
ernesteugene's Avatar
ernesteugene
Even with a 70 mph airspeed into your Zoodad, the increased dynamic pressure is only 3" H20 (0.1 psi) above static ambient pressure which is typically 14.7 psi at sea level, so it's less than a 1% increase. See post #25 here...
https://www.ford-trucks.com/forums/7...ml#post6003042
for some additional details as to how the Zoodad enhances performance.
Old Apr 18, 2008 | 09:38 PM
randomhero1172
Ya! thats exactly what i was thinking ...
Old Apr 19, 2008 | 10:58 AM
tumbleweed2
Oh my gosh! I think he drove thru a yard sale and obviously hit a lamp!
LOL. Ok, thanks guys. We would have heard something bad with air fluxuation (spell) by now.
I agree, the question is if it does anything at all?? Hopefully sand doensent stucco the filter.
Thanks for all imput
Ryan
