Changing the stator on my distributor
Old 04-29-2008, 06:43 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
I wouldn't knock myself out over the resistance of the wires. I know some on the board would recomend going to a conventional electrode motorcraft plug, though. You might be off a tooth or 2 with your dist drive gear. But near as I can tell, you've yet to check the wires at night, which will definitely show cross-fire.
  #32
Old 04-29-2008, 07:45 AM
78bigunns's Avatar
78bigunns
78bigunns is offline
True, I haven't checked them out in the dark.
It completely slips my mind.
I saw a vid on youtube where a guy spritzed his cables in the dark with a water bottle to increase any arcing for better visibility.
I was surprised to say the least at how much was jumping.
  #33
Old 05-04-2008, 07:04 AM
78bigunns's Avatar
78bigunns
Replace dis, truck runs tip top.
I guess it's not a good idea when resettin roll pins to lay the dis on the tollbox and beat them in with a 3lb hammer.
Lesson learned.
Thanks for all the help and advise.
  #34
Old 06-30-2008, 09:35 AM
78bigunns's Avatar
78bigunns
Follow-up, truck runs excellant.
Well except for the brakes, A/c, leaky front axle seal, non-working tank sending unit, cracked exhuast manifold, and broke tailgate.
But she goes down the road good!!!!!
mark1986F150
06-08-2017 08:00 PM
tkisling
17
12-22-2016 10:45 PM
lm987
10-19-2015 07:32 PM
hooler1
03-31-2015 06:50 AM
cartmans_twin
32
12-21-2011 08:11 AM
Quick Reply: Changing the stator on my distributor
