Sponsored by: Auxito
What is this hose called?
Old Apr 18, 2008 | 12:14 AM
xaviers_ford's Avatar
xaviers_ford
Question to anyone, this hose (red arrow pointing to it) on a Ford 2000 feels like its tearing apart and I want to replace before it tears or breaks apart. Problem is I don't know the name of it. I'm learning as I go. I've showed a couple of auto stores and they don't seem to know either. The hose comes from what I believe is the vapor management valve to the throttle body I'm thinking its a vacuum hose. On the vapor management valve it has like a little clip so I think its specialty hose. Any ideas? Thanks in advance.
Old Apr 18, 2008 | 05:15 AM
chaser1602's Avatar
chaser1602
I will take a WAG at this since I cant see it and say it is the a hose from the EVAP system.I have not seen them named.It should be pictured on the vacuum diagram under the hood.Maybe you should try the dorf stealer for that part.
