Help with decipering engine casting codes
Old Feb 23, 2002 | 02:58 PM
HotWhlz85's Avatar
HotWhlz85
Can anyone decipher this casting code for me?
D9AE-6015-ED 8
8H22
This is how it appears on the block with the 4 lower digits below and to the right of the top casting code.
Also the heads are stamped D90E which I think means they are 79 heads. Is there anything else about those heads that the code tells?
Thanks for the help guys.
Old Feb 24, 2002 | 09:05 PM
351Inside's Avatar
351Inside
Your block seems to be a small block designed for the LTD line of cars, cast on Aug 22, 1978. The heads are for Ford cars, cast in or around 1979.
Old Feb 25, 2002 | 08:50 PM
dpattonfl's Avatar
dpattonfl
